RYFT Exhaust
Old Mar 3, 2022 | 10:43 AM
BPG63718's Avatar
2020 Mercedes G63
RYFT Exhaust
I bought this RYFT Exhaust used a couple months ago and was told it would fit my 2020 G63 it did not apparently it is for the older model i am looking to sell it now but i do not want to tell the next owner wrong information could someone help on which model this exhaust will fit does it fit a G63 , G55 or both
Old Mar 3, 2022 | 11:04 AM
slk320's Avatar
Thats very pretty....
Old Mar 3, 2022 | 11:26 AM
BPG63718's Avatar
2020 Mercedes G63
I Know to pretty! made me buy it with out doing proper research
Old Mar 3, 2022 | 12:46 PM
PeriodCorrect's Avatar
2011 G550
The last photo dictates it’ll fit a w463 G63 which is a 2013-2018 G63. I’m sure you could make it fit any 463 (2002-2018) with a degree of modification, but if the plaque is accurate, it’ll fit 13-18 G63 models with no issue.
Old Mar 3, 2022 | 01:15 PM
BPG63718's Avatar
2020 Mercedes G63
Ok that is what thought just wanted to confirm that. Thank you !
Old Mar 3, 2022 | 03:42 PM
Minoclan's Avatar
G63
Do you have any sound videos? Price? I have a 2016
Old Mar 4, 2022 | 08:24 AM
The Butcher's Avatar
G63, G65
@BPG63718 did it come with any hardware, or just what you have pictured? The rear hangers on that setup looks like it would require bolts to hook up to the exhaust hangers that are toward the rear of the truck. The G63 exhaust (all years) has rods welded to the mufflers that insert into rubber bumpers that are the rear exhaust hangers.
For what it's worth, it might be able to be used on a G55, but it might not be a direct bolt in. As I'm sure you found on your W463A, the clearance between the frame rail and body was not enough for the wide mufflers that fit on the pre-'19 models. The G55 and G63 should have the same clearance between the frame and body.
Old Mar 4, 2022 | 08:49 AM
BPG63718's Avatar
2020 Mercedes G63
Yea just what is pictured the shop i took it too said they would have to make custom hangers for it. But when we tried on my 2020 there was just no way to make it work.
I think you are correct with the G55 it probably will work with some customization not like on the W463A where it just totally did not fit
Old Mar 4, 2022 | 01:04 PM
WillinMA's Avatar
2020 G550
It could also be that you remove the bracket that holds the 2 rubber donuts for the G63 mufflers (W463) and you replace it with the mufflers rigid bracket. The bracket just attaches to the car with 2 bolts like what is at the end of the muffler brackets. I know when you switch from G550 mufflers to G63, you need to replace the existing hanger with the G63 hanger - and its 2 bolts for those brackets (G550 or G63) just like on the mufflers you pictured. So it could be that if you remove the OEM bracket on either the G550 or G63, the exhaust fits by mounting directly to where the OEM bracket goes!! So it could be made for either the G550 and G63 (W463)
But the front flange (where it mounts to the cats) is a dead giveaway its for a W463 and not a W463A. The newer model mufflers connect with 1 V groove band that connects the two flanges. The older style connects with 3 bolts/nuts through the flanges... the other dead giveaway its that those mufflers use vacuum lines to operate the open/close of the valves. Thats how you would do it on the W463 - but on the W463A, if you have a G63 or Sport muffler, the flaps are electronic and not vacuum lines (which hopefully they gave you that portion as the new W463 owner would need to run lines to the engine to get the vacuum off the brake booster to use the flaps.)
Old Mar 6, 2022 | 09:50 AM
FatTony001's Avatar
CLK 55 AMG 2005 and CLK 63 AMG cab.2007 - 2009 EVO - 2013 ML63 AMG - 2018 G63 AMG
Looks beautiful. I cant find any online videos of this exhaust on a W463. Anyone found one?
even there website dont have any Mercedes
Old Mar 7, 2022 | 12:22 AM
black06c230's Avatar
mgLipGD
Holy hell the price
https://www.ebay.com/itm/RYFT-MERCED...-127632-2357-0
Old Sep 14, 2024 | 09:14 AM
Texas E63's Avatar
Built 2008 G55 & one big 80 Series LandCruiser !
These were very limited in production.... There was a G55 with one in NC for sale last year - I recall he had to do a small pipe section to fit it, plus mild hanger changes.....
what are you asking for it ?
