My 2016 G63 on 35" tires with a 4" lift
Old Apr 24, 2022 | 09:41 AM
2016-AMG-G63's Avatar
2016 AMG G63
I have a roof rack still coming, and my 30mm H&R spacers are going to be swapped for 50mm, but here's how Stitch sits now. It rides great and I'm planning a shakedown run today on some pretty technical trails. I'm happy to update this thread with those photos/videos.
I still feel that this is how G Wagons should come from the factory - or very close to it. It's disappointing to see so little aftermarket support for these cool rigs.
Oh - and in July I am running The Rubicon Trail with some friends. As far as I know, I will be the first person to attempt a G63 through that trail.
Old Apr 24, 2022 | 11:59 AM
shiann's Avatar
2005 G55K
Great looking rig. Pretty unique and cool color also.
Great to see the AlphaEquipt wheels on a 63 with the larger brakes. Too bad more 18" wheels don't work with the larger AMG brakes.
How is the hitch mounted spare tire carrier swing out? Does it just clear the bottom of the cargo door?
If you're planning on extended off roading trips, an auxiliary fuel tank may be important as the range per tank on AMG G's is pretty terrible.
Old Apr 24, 2022 | 12:26 PM
JD101b's Avatar
2015 SL550, 2017 GLS 550, 2010 G550, 1995 E320 Cabriolet
"3LOCKRS"
Great looking truck. What kind of lift kit did you use or did you put it together yourself? What is the width on the tires?
Old Apr 25, 2022 | 10:10 AM
2016 AMG G63
The Rigd hitch-mounted swing out is incredible. Extremely stout, has a built-in camping table and other accessories available. I had to get an extension/adapter from Curt. Something like 4" out and 4" up to clear the back bumper, then I had to Dremel a square cutout for the hitch to pass through the bumper for the pin to go through. Pretty easy mod, only took about 5 minutes and it's not easily seen to the natked eye. The swingout barely clears the rear door, which is exactly what I was hoping for.
For long off road trips, I have two, 4 gallon rotopax that will go on my Frontrunner roof rack here before long. Other than crazy long off road trips, the G tank seems fine to me. I previously had a 200 series land cruiser that was such a pig with a small tank - it would not even do 200 miles on a full tank. So the G63 seems good by comparison!
Old Apr 25, 2022 | 10:12 AM
2016 AMG G63
Originally Posted by JD101b
"3LOCKRS"
Jack Wagon Overlanding 4" kit (I had to source the springs elsewhere - those are Eurowise 100mm springs). I had my local MB dealership install the lift and they did a great job. The tires are 35x12.5 BFG KO2s. IMO, the best all-around tire out there, and I've used a lot of them.
Old Apr 25, 2022 | 11:46 AM
JD101b's Avatar
That's nice that your dealership did the install. Mine won't touch a lift kit.
Old Apr 25, 2022 | 05:34 PM
Texas E63's Avatar
Built 2008 G55 & one big 80 Series LandCruiser !
Looks GREAT, and the plate matches..... what's next ?
Old May 8, 2022 | 10:02 AM
amgw463's Avatar
AMG G63
This looks awesome.
Old Jun 11, 2022 | 01:20 AM
cbwagon's Avatar
2013 G63 AMG
Great looking build (and color)! Can you post a link to the Rigd hitch-mounted swing out model you used? Do you think it can fit with a rear ladder installed?
Looking to do something similar once I remove my stock spare and take the true spare off the rack to help with the center of gravity for trails.
Old Jun 29, 2022 | 03:54 PM
Texas E63's Avatar
CBwagon - how do you like that ladder ?
Old Jun 30, 2022 | 12:16 AM
cbwagon's Avatar
2013 G63 AMG
I loved the utilitarian aesthetic of it and didn’t think much of the functionality prior to installing. Now I find myself climbing up constantly to load up fishing rods, surf boards, etc. Definitely comes in handy especially for a lifted G. Really solid fitment and didn’t require any drilling for the install which was an added bonus.
Old Jun 30, 2022 | 12:24 PM
Texas E63's Avatar
Thanks - adding to my list....which keeps growing...
Old Jul 23, 2022 | 02:46 PM
C240-Merc's Avatar
2017 G63 AMG, 2019 G550
Nice work. Just to clarify, you didn’t use any spring spacers on your lift, just the springs.
also, what kind of shocks are you running and did you correct your caster angle?
Old Jul 30, 2022 | 12:54 AM
Calig63's Avatar
G63
How was the rubicon?
Old Aug 7, 2022 | 04:57 PM
neilthomas's Avatar
2016 G63 AMG
hey man, i love your car a ton, and im very much looking into getting almost the exact same setup lift wheels tires you have right now, but am fairly inexperienced with what all goes into it. could you send me links to products you purchased? or names? thanks a ton!!
Old Aug 7, 2022 | 06:14 PM
Texas E63's Avatar
I think he shared that this is the Jackwagon 4" kit.... https://jackwagonoverlanding.com/collections/suspension I'm about to do the same and move up to a 325/65... What year/ model is your G ?
Old Aug 7, 2022 | 08:22 PM
neilthomas's Avatar
2016 G63 AMG
it’s 2016 g63, ik just not entirely sure what all i need to purchase for this project, not really any good guide online to the parts
Old Aug 8, 2022 | 10:33 AM
Texas E63's Avatar
Did you look at the parts on Jackwagon's site ? the decision really is to do a 2" lift with spring spacers and shocks and run 33's , or go all in on all the extra hardware and do the 4" kit to fit 35's....
Old Sep 1, 2022 | 09:41 PM
rhyno's Avatar
2016 G550 - 1999 G320 SWB - 2001 G320-Cabrio
+1 I would love to have more info and pics of which Rig’d swing out you used. What’s the max size tire that it can hold?
