Finally - a my G55 build can start...
Old Jan 24, 2024 | 07:52 PM
  #51
JD101b's Avatar
2015 SL550, 2017 GLS 550, 2010 G550, 1995 E320 Cabriolet
Originally Posted by xxaarraa
Love how the truck sits now. Really like the lights out front, that's on my list. Silver is also a good color for this car.
I park in a garage at home and work with a 7" clearance as well as airports and I barely make it. It's real close. I couldn't do a roof rack or roof lights for that reason, the G is a tall vehicle...
That's what stopped me from more than a 40mm lift and 34" tires...I'd be hitting the garage door cutout.
Old Jan 25, 2024 | 05:03 AM
  #52
Texas E63's Avatar
Built 2008 G55 & one big 80 Series LandCruiser !
yes - 2" is the logical play !
Old Jan 26, 2024 | 07:21 PM
  #53
georges.email's Avatar
2022 GLS450, 2013 G550, 2007 FJ Cruiser, 1970 VW Beetle, 2003 JEEP Wrangler, 2020 GL550
I ended spending the last few months on the jeep getting a new ARB front bumper / ARB rear tire carrier / rock sliders wheels and tires. Finishing with a paint job and then ill focus on my G, which im pretty sure now on the gobi rack, afn front and rears, underarmor, 3in lift, kings, etc...
Old Jan 27, 2024 | 07:33 AM
  #54
Texas E63's Avatar
Nice - Look forwards to your G build !
Old Jan 27, 2024 | 05:56 PM
  #55
Texas E63's Avatar
the new rims and tires are on.... liking the fit and not having spacers. Tires are very smooth and quiet -so far..
Thinking 37's will fit as rs182 has beta'ed......
Old Jan 28, 2024 | 09:11 PM
  #56
JD101b's Avatar
Wowza that looks great.
Old Mar 4, 2024 | 08:21 PM
  #57
Texas E63's Avatar
Pics of the JKUR?
Old Apr 2, 2024 | 07:30 PM
  #58
Texas E63's Avatar
The 315/70/18's and maybe the rims are in the classifieds for anyone with a 2" plus lift look for a spring tire setup.....
Old Apr 7, 2024 | 07:57 AM
  #59
Texas E63's Avatar
We had a pile of mulch delivered to the shop - so had to test the flex of the current lift and 36's ... we'd checked it with our forklift but this was more realistic... decent clearance but I can see some grinding and perhapsa 1-15mm spring spacer needed for the incoming 37's....
This also was a good reminder I need to get at the surface rust under the G..... and suggestions of other options to Fluid film once I brush and treat the rust ?
Old Apr 7, 2024 | 11:21 AM
  #60
JD101b's Avatar
a.) looking great
b.) B’laster surface shield or Lucas Red n’ Tacky. It kept existing rust from spreading any further during the 1.5 years I was unable to get the truck in a local shop to fix it (due to Covid). Both provide a thick, sticky layer that drives out moisture and both are formulated with chemicals to further inhibit corrosion. Lucas is the better product in my opinion because of just how difficult it is to remove (a direct application of degreaser plus mechanical abrasion still left a thin film on a test spot) but B’laster is extremely long lasting too - my chassis is still coated in a uniformly thin film after nearly two years. The only problem with Lucas is that the aerosol can version doesn’t do a great job of aerosolizing the grease well while B’laster can does (probably because of how much thicker the Lucas grease is). If you use Lucas, get an air gun with enough pressure to apply such a thick product.
c.) a local guy is selling a pristine set of G55 18” wheels along with low mile P-Zero scorpion tires. I’m thinking about buying them, selling the tires, and selling the tires and wheels presently on my G in favor of 285 75R18 ridge grapplers (up from the 70 series ridge grapplers presently on the G). That would being tire height from 33.7 to 34.8. I’ve been on some trails and tested full compression and lock and I’ve never rubbed. At present there is about 2.5 inches from the tire to the top of the fender flares. Would I be safe going up in size (or maybe even 295 75R18?) or would that be pushing it, in your opinion? Keep in mind that I only have a 40mm lift.
Old Apr 7, 2024 | 03:01 PM
  #61
Texas E63's Avatar
Thanks for the feedback on those two... will be digging a bit more and hoping to tackle that next weekend....
On the tires - 305's clear nicely with 40mm of lift.... and with the narrower 550 flares are right at the edge.
This is our old 63 with 305's on 20's (albeit on 20's - but they cleared fine)
if you wanted to add JWO's flares you could snag my Alphas and 325 Toyo's cheap-ish....
Old Apr 7, 2024 | 06:38 PM
  #62
JD101b's Avatar
That C looks dirty. Love it.
I fit a set of JWO fender flares not long ago. What aspect ratio are those tires?
Old Apr 7, 2024 | 07:26 PM
  #63
Texas E63's Avatar
haha - the C was a blast, sadly sold it to get a dog hauler...... the C was lightly hit in the rear when I first picked it up, and I decided to widebody it and tub the rear when we got into the motor....we ended up settling on 345's and an LSD to get it to hook up.
The toyo's on the grenades are 325/65/18's - full set of 5 rims/tires
with about 7k on them, all highway. https://www.discounttire.com/buy-tir...-t-iii/p/88422
Rims are like new - the Puch sticker comes right off....
Old Apr 8, 2024 | 06:32 AM
  #64
xxaarraa's Avatar
Multiple
@Texas E63 you are a good candidate for an ORC rear swaybar!
Old Apr 8, 2024 | 07:21 AM
  #65
Texas E63's Avatar
Agreed - but with the wider track the rig handles fairly well.... I'd like to do that if I could figure out a way to do a release pin and limiting straps like I installed on my 80 Series Landcruiser front swaybar..
Everything dialed in on your rig now ?
Old Apr 8, 2024 | 12:26 PM
  #66
xxaarraa's Avatar
Multiple
Should be fairly easy to do? Bottom of the ORC end link mounts to the swaybar with a through bolt. We should be able to simply replace that through bolt and nut with a quick release pin.
Yes, much improved. I have my eyes on a rear swaybar now.
Old Apr 8, 2024 | 01:55 PM
  #67
Texas E63's Avatar
Great to hear on it handling better finally..... just as a note I have found with our 63 and 55 that widening track with either wheel spacers/ lower offset rim or wider tires ( or both) truly change the handling - but that's also not for everyone.... my only worry with the thicker bar is that travel will suffer - it's fairly limited as it... although with Lockers is might be moot point 95% of the time !
Old Apr 8, 2024 | 08:35 PM
  #68
JD101b's Avatar
Jusssssssst out of curiosity...what are you selling those rims + tires for?
Old Apr 8, 2024 | 09:01 PM
  #69
Texas E63's Avatar
hehe - asking for a friend I'm sure.... I have a commercial ground account as well....
https://mbworld.org/forums/market/872535
