What’s best way to grease hinges ??
A heavy duty spray oil might be better at seeping into seams and cracks, but it's almost impossible to avoid oil overspray. Good oils will resist even a thorough was afterwards (after all, you want the product to be as sticky and long lasting as possible) so you might want to consider putting up paper over all local areas if you're going to use spray grease.
Are you looking to grease all of them?
For anti sqeak on the door seals I'd use a silicone grease, for under the windshield seal I'd use a water displacing corrosion inhibitor.
Because the 463 hinges are a closed design with no zerk traditional grease is too thick to fully coat or protect the 463 hinges and will only trap moisture into the center of the assembly.
