side trim
Old Apr 3, 2024 | 09:00 AM
Arasimowicz's Avatar
2014 G550
side trim
My G550 was previously wrapped and now the side trim pieces are curling up at the ends. Does anyone know how I can get them to lay flat again? I tried new double sided tape but that didnt work.
Old Apr 3, 2024 | 01:17 PM
JD101b's Avatar
2015 SL550, 2017 GLS 550, 2010 G550, 1995 E320 Cabriolet
Picture?
Old Apr 3, 2024 | 03:51 PM
shiann's Avatar
2005 G55K
The side rubber trim has a metal insert inside, so you'l have to bend it back to be straight. If it's curling only on the ends, there's a good chance it's been damaged enough or the rubber has shrank, so the only option will be to buy new pieces to replace.
Most times when wrap shops remove these for wrap, they pull and pry and damage these pieces.
Old Apr 30, 2025 | 05:02 AM
orfanidis360's Avatar
Mercedes G 500 2019
cxl
Old Apr 30, 2025 | 05:42 AM
streborx's Avatar
Top Answer: 1
G550
What type of double sided tape did you use that did not work?
Old Apr 30, 2025 | 08:19 AM
2014 G550
I think it was 3m and was told it was the strongest available. As it turns out the car was previosly wrapped and the trim pieces were removed improperly bending the metal in them. I recently had them removed again and bent back to lay flat After years of struggling with them they are finally all good!
