22 G63 mutlimedia issues
New 22, multimedia system did not show speed limit, nor Nav street details.
Reset unsuccessful
System update at the dealer ended with black screen.
The dealer wants to replace the whole system
Any similar problems?
Anyone knows how yo reset the multimedia system?
Thnx
Reset unsuccessful
Thnx
medtner (07-10-2022)
Interesting since I thought the '22 had the same COMAND system as the 19-21s. Wonder if it has something to do with the added Energizing Comfort program that I think is new for 2022.
Jblocker (07-10-2022)
You may want to manually download the update from the Mercedes me connect website. Sometimes the OTA updates can be glitchy!
https://id.mercedes-benz.com/ciam/auth/login
medtner (07-11-2022)
This maybe a better link:
https://www.me.mercedes-benz.com/pas...rcedes-me.html
This is from the work order.
198 NAVIGATION SOFTWARE CORRUPT PERFORMED QUICK TEST-NO FAULT CODES, CONNECT BATTERY MAINTAINER,
PERFORMED REPAIRS AS PER LI82.85-P-074970, DELETED NAVIGATION MAP DATA, PERFORMED NAVIGATION MAP UPDATE.
PERFORMED COMAND ONLINE FUNCTION CHECK AFTER REPAIRS-OK.
medtner (07-12-2022)
Many thanks
Guys - I picked up my '22 on Friday, and I do not seem to be experiencing the navigation issues described above, but CarPlay will not launch in the vehicle. I've tried a combination of different cables and different phones with no luck. After plugging the phone in, the CarPlay disclaimer pops up, but after about a minute the vehicle displays the following message: "CarPlay could not connect". Did anyone experience a similar issue as part of the multimedia issues noted in the initial post? I'm trying to figure out if my car is affected by the same software issue, or if I've got something else going on... Thank you!
