305/45/22 no rub on 2019 G550?
Anyone here know if 305/45/22 will rub on a 2019 G550? All the posts I'm reading point towards yes, and the safe tire is 285/45/22.
That being said, I found two setups done by Wheels Boutique using 305/45/22:
https://wheelsboutique.com/gallery/m...us-monoblock-z (this is the exact wheel and offset I am getting)
https://wheelsboutique.com/gallery/m...-on-hre-p104sc
Thanks in advance.
Thanks in advance.
my guess is that there will be some rubbing on full lock on the forward inner fender liner in the front. that being said i have a set of HRE p101SC in 22x10.5 with terra grappler g2's in 305/45/2022. they should get here end of next week and i can update whether or not there is any rubbing. the guy i bought them from had a g63 and he said there was NO rubbing.
Chedman13 (11-10-2022)
that would be amazing.
If you don’t rub, I’m getting 305/45/22 as my offset should be similar to what HRE recommends.
what year/model do you have?
Chedman13 (11-11-2022)
G wagon (W463a) and Carrera S (992)
I have the AMAZING Recon grappler in 305/45/22 on 22x10.5 wheel (offset i think 30) , and my car is lifted 50mm. The is a VERY minor rub at full lock. so little rubbing the you could barely hear it. I'm sure after few thousand miles it will disappear (after the tire wears out)
I ran Nitto Ridge Grapplers in 285/45/22's on my previous G and the front tires just cleared rubbing at full lock. Rear tires were fine of course.
Looks like 285/45/22 is 32.1" tire circumference and 305/45/22 is 32.8".
I would be very surprised if the 305's didn't rub without modifications. I mean the 285's cleared by millimeters.
What wheels did you use?
I might go with 285/45/22 to stay safe then - that size also has the tire I like (Falken Wildpeak A/T3W). I run them on two other cars and they are perfect for Midwest (no need to swap out winters/summers).
The 305/45/22 is nice though as more sidewall protection and more meaty look.
Merc G63, GTC4 Lusso and other redheads.
2019 AMG G63, Porsche GT4, 1973 Porsche 911 hotrod
@Drray81 any update if they rub or not? Also share some pictures!
any update if the 305's clear? Have 30mm spacers on OEM 22's and would love to fit the 305 Ridge Grappler if possible. Any intel appreciated.
