G Class (W465/W463A) W463 Produced 2019-2024: G550, G63 AMG W465 Produced 2025-
dead bugs on windshield and front grill
Old May 27, 2021 | 12:34 AM
manywheels's Avatar
2020 G550
Hi guys, I frequently drive the truck across states and always end up with billions of dead bugs on the windshield and front grill. Any recommendation on the bug removal product? Or any tricks that can make the truck less of a bug magnet? Thanks!
Popular Reply
May 27, 2021, 07:31 AM
streborx's Avatar
streborx
Top Answer: 1
G550
Science as of yet has no plausible explanation for the ability of bugs to deftly evade being clobbered by a fly swatter, yet inexplicably engage in this kamikazee ritual when confronted with a windshield. Toward furthering human comprehension of the cosmos, I plan to tape a couple fly swatters to my truck's grill and hang a used windshield in the corner of my kitchen. I will report my findings here, prior to publishing in Nature.
Old May 27, 2021 | 01:45 AM
Deezwho's Avatar
G550
I've read online about some stuff called Rejex that people swear by.
Should work on the grill and windshield to reduce the number of bugs that stick and make it easier to remove any that do manage to stick.
Old May 27, 2021 | 04:07 AM
black06c230's Avatar
mgLipGD
Purple Power is a great degreaser that helps get them off our cars. Also great to clean up exhaust tips!!
Old May 27, 2021 | 07:31 AM
streborx's Avatar
Top Answer: 1
G550
Old May 27, 2021 | 08:04 AM
places's Avatar
No more MB:(
This is genius. On standby for said report.
Old May 29, 2021 | 01:55 AM
Festertester's Avatar
‘13 911-4S, ‘21 CTR, '22 GT4, ‘19 G63
Bug deflector?
https://www.weathertech.com/mercedes...bug-deflector/
Old May 29, 2021 | 01:24 PM
streborx's Avatar
Top Answer: 1
G550
Originally Posted by Festertester
I have this type of deflector on my Rubicon, and it's effective blocking stones and bugs from striking the hood directly beneath it, but it does nothing to deflect either annoyance away from the windshield.
Old May 31, 2021 | 10:23 PM
Jagdpanzer's Avatar
Mercedes G63
I have tried everything and have the best test mule ever, my motorcycle. There are two things I found that work decent. One is a good coat of slippery wax, that does help them release. The other is a pressure washer with a turbo tip on it. Thats the little tip that swirls around real fast. It will take off any and all bugs with no paint damage. I run mine through a deionizer for spot free washing. A little soap and blast the stuff off and a quick rinse. U can also get bug remover to add to a prewash to soften them up if you want.
Old Jun 1, 2021 | 08:42 PM
streborx's Avatar
Top Answer: 1
G550
I recall driving through Montana in late July several years ago -- I-90 in my Jeep with the top off around dusk. The only time I ever had to pull over and use my shoe to scrape the bug residue off the glass. Completely destroyed a set of wiper blades.
Old Jun 2, 2021 | 06:09 PM
manywheels's Avatar
2020 G550
Thank you guys for the replies! I will try out some of the products you guys recommended.
Old Jun 2, 2021 | 09:59 PM
Jagdpanzer's Avatar
Mercedes G63
No problem. I would try sitting in the back while someone drives you first, and you could even get a mechanic stethoscope. I have seen mechanics use them to find noises when I worked in a garage.
Amazon Amazon
Sometimes you can just get a couple people to rock the vehicle with you inside to listen. More of a long shot but you never know. With the road noise gone and the engine off, things are much easier to hear
Old Nov 28, 2022 | 05:06 AM
annalim2008's Avatar
RX 350
The best way to get rid of bugs’ dead bodies from your car windshield is with vinegar. It’s an excellent cleaner and also really easy to find in any household.
Old Dec 12, 2022 | 01:04 PM
Calig63's Avatar
G63
I found even easier is to keep them from sticking in the first place. After I put on my windshield protection film, I had my detailer put on ceramic coating. You can watch a bug hit the window and get smashed, then slowly slide up and off the top of the windshield while you're driving, since it doesn't stick.
