Another AT tire option Scorpion All Terrain Plus
Subscribe
Nov 16, 2021 | 02:13 PM
I am running HRE 22" for the summer and just took them off for the winter...for the winter set I took the OEM tires off and put Scorpion All Terrain Plus tires on the OEM 20" wheels. Went with 275/55/20 size with 31MM H&R spacers. Its pretty quiet (same as the summer tires on my 22") and drives nicely! I had to do a little plastic surgery on the wheel well front vents to not have them rub at full turn - but it was minor, just heated up the bottom 3 rows and pushed the vents flat....
Reply 1
Nov 16, 2021 | 03:16 PM
Is it the 31mm spacers that cause the tires to rub? OE tire size on 20" wheels is 275/50R20. I mounted 275/55R20 A/T tires (Geolandars) and the tires don't come close to rubbing.
Reply 0
Nov 16, 2021 | 05:13 PM
I don't know if its the spacers or the type of tires... when I swapped the tires I mounted the spacers and never tried them without! You might be right because its the outside edge of the wheel that rubs in the wheel well - so there is definitely more space if the wheels are set in a bit ...
Reply 0
Nov 18, 2021 | 11:09 PM
We had the Pirelli Scorpion All Terrain Plus on our 2020 G63 - 275/55R20. Tire was great, no rubbing.
Reply 0
Nov 19, 2021 | 07:41 AM
Quote: We had the Pirelli Scorpion All Terrain Plus on our 2020 G63 - 275/55R20. Tire was great, no rubbing.
Looks to me like you are not running spacers, so it must be the spacers that are causing the rub in the front wheel wells!! The rub with the spacers is minor - I think with the adjustment I made in the wheel well it basically gave me lie 1/2" more clearance and thats all that is needed!!!
Reply 0
Feb 2, 2025 | 06:07 PM
Looks great. Thinking about ordering the same. Can that size of tire fit under the manufacturer's spare tire cover?
Reply 0
Feb 4, 2025 | 09:28 AM
It can’t (but neither can the stock 275/50/20 size which is why the spare is slightly smaller than full-size).
Reply 0
Feb 4, 2025 | 12:41 PM
Quote: It can’t (but neither can the stock 275/50/20 size which is why the spare is slightly smaller than full-size).
I've previously b****ed about this sub-size spare tire in other forum posts. The spare tire has a 45MPH Max sticker pasted on it, and I don't think driving with a lop-sided setup would be especially healthy for the differentials. But my main complaint is what do you do with the spare tire cover after you've mounted the flat tire on the spare tire bracket? The cover won't fit around the 275/50R20 (the spare is a 265/50R20 as I recall), and your cargo space is full of luggage. Whose brain was out to lunch when MB marketing signed off on this idea? I changed out the Pirelli OE tires and mounted Yoko Geolander A/T's in 275/55R20, and bought a larger hard shell tire cover from Boomerang Enterprises. I've posted photos in some threads about 4 years ago.
Reply 0
Explore
Subscribe
Currently Active Users (1)
