Very Squeaky Brakes on 2021 G63
My new G63 was making squeaky braking noises at around 5000 KMs. It went away and now it's come back even squeakier... I'm at 10k KMs so I don't know what the issue is (if it's even an issue).
It goes away if I ease on the brakes slightly or if I brake really hard. But if I brake normally, it just squeaks and it's quite embarrassing to be honest.
Any cleaners or something I should try on the rotors? Anyone experience the same thing?
the sad part is all aftermarket solutions are a waste of time and money.
the good thing is they wear out pretty quickly.
Front set: $270 Part # HCD2238
Rear set: $250 Part # HCD2239
MB ain't gonna risk that
Not to mention carbon brakes are good for track use, but pretty jarring for everyday use. My GTC has them which is appropriate, but I think it would feel odd in a G.
Gaslighting 101.
it’s like 3-5x longer considering how quickly they fade on this truck, or more if you live in the northeast.
but I give up … i forgot that the G63 is a military spec off road vehicle with 563hp and sport tires bought entirely by purists. My bad.
But by your logic, maybe they should lower the ride height so it can fit into carparks? Maybe remove the locking diff? What about a FWD version for city driving only?
Most OTT luxury things have engineering abilities that nobody will ever use. Like very high end luxury watches. Most of those watches will only see a few splashes of water in their life, let alone make it 100m deep in the pacific. Who uses an actual chronometer?
If the pistons do not retract this can lead to one or more pads remaining in slight contact with the rotor. This produces a mild glazing which is where the squeal/squeak comes from.
Wash the brakes. No need to jam the wash nozzle down close to the pads/piston dust boots. I use the wand soap setting then follow with the wand setting set rinse then finish with the no spot rinse setting.
To get an idea of how much brake dust there might be, the 1st time start with the regular rinse setting first to see what the water rinses off the brake (and wheel). In my experience this water will be quite dark with brake dust. Sure some dust is from the wheel which is harmless (though somewhat unsightly) but some comes from the dust boots.
Be sure to after you wash the brakes to use the brakes some as you drive out of the bay to remove some water. Then on the road arrange to use the brakes enough to get them hot to dry not only the exposed brake hardware thoroughly but any emergency/parking brake hardware which can be inside the rear wheel/brake hubs.
In fact I treat the just washed brakes to a mini brake bedding in process of at high way speed applying the brakes to cause a pretty good slow down and doing this several times in rapid succession. The idea is to get the brakes hot and remove the glaze that has developed. As with the regular brake bedding in process you do not want to bring the vehicle to a complete stop just a slow down from say 65mph to say 50mph in a rather aggressive manner although you want to be sure you can do this without causing any issues with other vehicles on the road.
After the brakes are hot then drive normally long enough the brakes cool down.
I find the washing process helps eliminate brake squeal/squeak. But it doesn't last. As soon as one uses the brakes after the wash the brake dust begins accumulating again. It is the consequence of having large powerful disc brakes.
All three cars had the squeaky brake syndrome - and for all three I was told its not unusual and there was nothing Porsche service could do.
In fact the Cayenne GTS brakes squealed so loud and it was so embarrassing ( my wife refused to drive the car which wasnt a bad thing if you know what I mean) after a year of owning it I traded it in for my G63.
Guess what - the brakes on the G63 also squeak - but not as bad and I love the car so I don't care.
Maybe its just me - but be careful what you wish for
