G Class (W465/W463A) W463 Produced 2019-2024: G550, G63 AMG W465 Produced 2025-
death to running boards.
Old Sep 2, 2022 | 09:07 PM
nrh3k's Avatar
2019 G550
Apologies for the dirty car. I'll make a follow-up post with part numbers and better photos later, but here's a teaser in the meantime...
Attached Thumbnails death to running boards.-img_3477.png   death to running boards.-img_3478.png
Old Sep 2, 2022 | 09:46 PM
achatgrau's Avatar
Interesting. Are you planning for some rock sliders?
Old Sep 5, 2022 | 08:26 AM
amgw463's Avatar
AMG G63
Hello, I have been trying to find mud flaps but I cannot find the part number or where to buy them. I got G63, 2017. Any info would be great.
Old Oct 16, 2022 | 12:52 PM
nrh3k's Avatar
2019 G550
I do plan to build some sliders at some point, that might be a next summer project.
The mudflap thing is a little complicated. Basically, there does exist a front mudflap set for the W463A, but they are *not compatible* with the running boards. The OEM ones you see here are only really possible to install with the side moulding from the professional series.
The rear OEM rear mudflaps work either way.
This is the OEM set I bought from Mercteil. I think they should be available from US dealers now that the professional line is sold in the US: https://mercteil.com/mud-flaps-kit-f...retrofit-0Rxx9
Here's a parts list for converting to the Professional-style side trim.
A4636929900|RETAINING STRIP|4|463350||FRONT & REAR,LEFT|
A4636982301|BRACKET|5|463350||LEFT|
A4636929900|RETAINING STRIP|4|463350||FRONT AND REAR, RIGHT|
A4636982301|BRACKET|5|463350||RIGHT|
N304017008016|HEXAGON HEAD BOLT|9|463350||RIGHT; M8X16|
N304017008016|HEXAGON HEAD BOLT|9|463350||LEFT; M8X16|
A4636200301|REINFORCEMENT|1|463350||BOTTOM LEFT|
A4636200401|REINFORCEMENT|1|463350||BOTTOM RIGHT|
A4636901802|MOUNTING RAIL|1|463350||FRONT RIGHT|
A4636906702|MOUNTING RAIL|1|463350||REAR RIGHT|
A4636928401|STIFFENING|1|463350||Right rear|
A4636928201|STIFFENING|1|463350||Front right|
A4636928301|STIFFENING|1|463350||Rear left|
A4636928101|STIFFENING|1|463350||Left front|
A46369036027C45|TRIM, SIDE WALL|1|463350||Left|
A46369073027C45|TRIM, SIDE WALL|1|463350||Left|
A0009907892|EXPANSION RIVET|2|463350||LEFT BOTTOM|
A0009907892|EXPANSION RIVET|2|463350||RIGHT BOTTOM|
A20199002929051|EXPANSION RIVET|14|463350||RIGHT COVERING; 8 MM|
A20199002929051|EXPANSION RIVET|14|463350||LEFT COVERING; 8 MM|
N000000006037|NUT-AND-WASHER ASSEMBLY|2|463350||RIGHT STIFFENING; M6|
N000000006037|NUT-AND-WASHER ASSEMBLY|2|463350||LEFT STIFFENING; M6|
A0009927900|COLLAR SLEEVE|2|463350||RIGHT REINFORCEMENT|
A0009927900|COLLAR SLEEVE|2|463350||LEFT STIFFENING|
A00099193409999|EXPANSION RIVET|2|463350||RIGHT|
A00099193409999|EXPANSION RIVET|2|463350||LEFT|
A20199002929051|EXPANSION RIVET|2|463350||RIGHT; 8 MM|
A20199002929051|EXPANSION RIVET|2|463350||LEFT; 8 MM|
N000000000543|TAPPING SCREW|2|463350||RIGHT FRONT AND REAR; 6.3X19|
N000000000543|TAPPING SCREW|2|463350||LEFT FRONT AND REAR; 6.3X19|
N000988008024|SHIM|2|463350||RIGHT FRONT AND REAR|
N000988008024|SHIM|2|463350||LEFT FRONT AND REAR|
N304017008034|HEXAGON HEAD BOLT|3|463350||REINFORCEMENT FASTENING RIGHT; M8X25|
N304017008034|HEXAGON HEAD BOLT|3|463350||FASTENING TO LEFT REINFORCEMENT; M8X25|
A1089900340|WINDOW|3|463350||REINFORCEMENT FASTENING RIGHT|
A1089900340|WINDOW|3|463350||FASTENING TO LEFT REINFORCEMENT|
Attached Thumbnails death to running boards.-screen-shot-2022-10-16-12.50.41-pm.png
Old Oct 16, 2022 | 01:09 PM
nrh3k's Avatar
2019 G550
Apologies - 2017 is a W463, not W463A. I don't have any information on mudflaps for a W463. Try the W463-specific forum, this one is for 2019+
Old Oct 16, 2022 | 01:26 PM
achatgrau's Avatar
From the mercteil kit, do you remember what subset of the mounting hardware you used for the rear flaps?
Old Oct 16, 2022 | 02:48 PM
nrh3k's Avatar
2019 G550
A0039948545|SPRING NUT|1|463261||Left rear fender flare; 4.8/0.5-2.5 MM|
A0039948545|SPRING NUT|1|463261||Right rear fender flare; 4.8/0.5-2.5 MM|
N000000000925|TAPPING SCREW|4|463261||Rear mud flap mount; 4.8X19|
N000000000925|TAPPING SCREW|6|463261||Rear mud flap mount; 4.8X19|
N000000002349|HEXALOBULAR BOLT|4|463261||Rear mud flap mount; 6X16|
A46388931007C45|MUD FLAP|1|463261||Rear left|
A46388932007C45|MUD FLAP|1|463261||Right rear|
Old Oct 17, 2022 | 09:39 AM
amgw463's Avatar
AMG G63
This is a great start, and thanks a million.
Old Oct 17, 2022 | 10:51 AM
achatgrau's Avatar
Awesome! Thanks for your help.
