Out-of-warranty G63 with oil leak from the back of the engine
I caught an MB SA lying to me and he looked like a little girl piddling her pants and looking for her mommy when he realized he wasn't going to get away with his blatant lie. He was a bit young and not very practiced lying, evidently.
Glad you got the vehicle out of there and back on the road.
when it blows out again I’ll be there bright and early in the morning to get my new free rear main seal which will restart my 2 year unlimited mile warranty on THAT rear main seal. Lol. Replay that game as long as I have to. And if they try to pull the “well you declined the repair for the oil separators” I’ll be the first one with the email and texts in hand from the service advisor telling me “well the oil separators causing this is purely anecdotal, no way to know if that was the cause so we can’t cover it”
😂😂 ….. “well when you barked at me that it was anecdotal, when I diagnosed it for you, and the oil separators causes this…. you told me you wouldn’t cover it, because it’s anecdotal…. I ’ll be sure to remind you it’s still anecdotal now also, and if MB issues a TSB for the oil separator between now and then, then looks like those will be replaced free also. So when that time comes I’ll tell you to go ahead and put a new rear main seal in for me, free of charge of course”
So with that said, I dont think it has anything to do with the G63 specifically, it has to do with the MB M177 motor.
It didn't happen all the time. Sometimes it did it the entire drive, other times zero sound.
So the repair is putting in new air/oil separators and new rear main seal gasket.
After this is done, and you're out of warranty - he suggested to proactively change the air/oil separator around 20-30k miles to avoid the rear main seal leak. Since the M177 engine has a lot of stuff up front to remove, when you're in there - you might as also replace the thermostat if you haven't already as those also fail around 40k miles and is a lot of labor if done separately.
in fact, an aftermarket company is working on the E63 platform to create what they think is a definitive solution, way ahead of Mercedes, who doesn't even acknowledge that this is an official problem.
https://www.63motorsports.com/amg-bl...er-m177-update
Great info on e63 rms issue / must read
I had the RMS replaced, and when they wouldn't replace the OVS under warranty I told them to F OFF. I also told them that since MB Dealers are mandated to include a 2 yr, unlimited mile warranty on repairs, that the good news for me is, if the RMS goes out AGAIN soon after it was replaced (since I did not change out the OVS) then they could just go ahead and replace the RMS again, for free. And they can keep doing this over and over and over until they actually fix the cause under warranty which is the OVS. The RMS is an effect, not the cause.
ill also note, it was about a year ago I had this done, i've put about 10k miles on the car since then and ive seen no oil drops, and no signs of another RMS failure, (yet). Even with out replacing the OVS.
Now I suppose its entirely possible they cleaned out the OVS, or maybe they did replace them and just didnt want to tell me ( both of these are doubtful of course)... BUT... I haven't had a NEW RMS leak occur (yet). With my luck it'll blow again just after the 2 year mark. But I doubt I'll have the car that long anyway.
MB knows damn well whats going on. They just give us all a fat middle finger.
In fact, it's well documented internally. They know. There is literature on it. they just wont give it to you. internal only. And part of it is HOW they properly diagnose it. Because of the specific way the RMS blows, it's a tell tale sign of a OVS failure if it sucks in, vs a more obvious blow out, or defective RMS. If it sucks in like that, thats how MB has identified it is indeed an OVS issue. They just wont fix the OVS. Even though it SHOULD have a 8yr 80k emissions warranty... but they covered themselves on that end also. By the OVS being one of like 2 or 3 parts of the emission system that is NOT covered under the 8/80k emission warranty.
MB executives are scum bags. Plain and simple.
IF we want something happen there needs to be a class action lawsuit. But doubt that'll happen.
MB does not stand behind its products, the M17x OVS and RMS failure is one of many examples.
VAG/Porsche on the other hand is better. Not perfect, but better. 992 911 and early 9Y0 Cayenne were factory build with LiFePO4 batteries which often fail in less than 4 years because of electronic module failure built into the battery. The battery itself costs up to $2,000 at the dealer, and the dealer charges $1,000 for installation and coding.
When the failures started, Porsche did not help owners. Because the failures are relatively widespread, Porsche is covering LiFePO4 battery replacement under the emissions warranty.
Porsche ownership experience = far better than MB ownership experience.
