G Class (W465/W463A) W463 Produced 2019-2024: G550, G63 AMG W465 Produced 2025-
Auto Folding Mirrors not Working - 2022 G550
Old Oct 1, 2023 | 05:08 PM
betzgb@att.net's Avatar
2022 G550
My 2022 G550 is having a problem where the auto folding side mirrors are not folding when you exit and lock the vehicle . I think it used to work in the past but not anymore. I have tried the procedure below I found in another thread but no luck. Any ideas? Thanks!
Folding Mirrors
1 go into menu and turn auto fold off.
2 exit menu
3 turn car off, go out and lock car
4 open car and restart
5 go to menu and turn auto fold on
6 exit menu
7 turn car off
8 lock car from outside of car
Old Oct 1, 2023 | 05:19 PM
sampelligrino's Avatar
G63, F12, 911 50th
Folding Mirrors
2 exit menu
6 exit menu
7 turn car off
My 21 G63 has this issue as well, where if I turn the setting on and off it will work for awhile, then eventually forget. But when I press the fold mirror button on the driver's side door they always fold. Kinda annoying. My solution was to upgrade the car..
Old Oct 1, 2023 | 05:22 PM
streborx's Avatar
Top Answer: 1
G550
Did you try pressing and holding the mirror folding button on the mirror switch cluster?
Old Oct 1, 2023 | 05:53 PM
Hodog16's Avatar
2026 G63
This has happened to my 2023 like 4 times. Initially I tried to toggle the menu on and off but I found out if I just hit the mirror fold button on and off while the car is on it'll work again at lock.
Old Oct 1, 2023 | 06:46 PM
tonygwagon's Avatar
G550
I have the same issue on my 21 G550. Sometimes it works when locking on the key fob and sometimes it doesn’t…
Old Oct 1, 2023 | 08:41 PM
2022 G550
Thanks Hodog16! That did the trick. I just started the car, hit the fold switch on the door to fold in then back out again. Turned the car off and locked the doors and they automatically folded in. Weird but glad it worked.
Old Oct 3, 2023 | 09:46 PM
G63, F12, 911 50th
This is a hell of a lot faster than going into the settings via command/screen and toggling it on and off, worked like a charm for me today
Old Jun 17, 2025 | 01:14 PM
a4ep's Avatar
`22 G63
Just had this issue with my 2022 G63. Toggling in the system didn't fix it but clicking the little physical button when the car was on to fold and unfold did the trick! Thank you all.
Old Jun 17, 2025 | 01:57 PM
Craig B's Avatar
2025 G 63
I had the same problem with my 21 G 63 and 24 G 63. Did the same thing Hogdog did and it worked afterwards. Haven’t had the problem with my 25 G 63.
Old Jun 20, 2025 | 11:27 PM
arya0807's Avatar
G63, C63S
I’ve had this issue a handful of times. As the poster above said, hitting the fold mirror button fixes it. Wonder if MB will have a software update in the future to fix it
