Towing
I have a 2019 G63, it's been solid, and i've towed a couple small light trailers behind it very easily, with no issues. Under 1000lbs probably.
Question is, I am planning to tow a flatbed trailer to transport a G80 M3 on it about 350 miles one way. And will tow back the same distance. Basically from Scottsdale to Los Angeles.
Less worried about the drive to LA, and a little concerned about coming out of Palm Springs area on the way back with a pretty large, long slope uphill. Also will likely be over 100 degrees the majority of the trip until getting closer to LA.
Ive had escalades and Denalis, that would tow 5-6-7000 lb boats with out much issue. The M3 is about 3700-3800 lbs, and a trailer I would imagine will be at least another 1000-1500lbs.
So total will be 4700-5500lbs-ish.
Am I crazy? I feel like it shouldn't have much issue, but I have not towed anything of any significance with the G63 so far.
Anyone have thoughts or suggestions, or should I not even consider this?
yes I know the towing capacity is ok. I was more wondering if there is anything I should be concerned with ? Would this type of tow raise any concerns with anyone ? Regardless of the tow capacity, the heat and hills are what I’m worried about with the transmission etc, or should it handle it with out any issue ?
There's also the issue of conforming with the G's tongue weight spec and ensuring the trailer's braking system can be controlled by the G. Rental trucks are setup and intended for towing -- they remove all the guesswork.
wear and tare are part of it certainly. Capability I’m sure it can handle it.
was mostly wondering if there is inherent issues any one has seen or knows about with this type of tow.
yes, it will be 100-110 the majority of the way, both directions until metro LA.
However I wouldn’t say this vehicle has spent its life towing. This would only be the second time it’s towed anything ever. And the first time was about 20 miles with a very small trailer that didn’t weight very much.
I would simply prefer not to grenade the transmission in the middle of the desert in the summer.
we are taking his 1100hp M3 over to the Bimmerinvasion show as it’s a featured car, and thought it would be kind of cool to tow it behind the G63 up to a car show. That’s pretty much the only reason for it.
The M3 weighs about 3800 lbs, trailer was about 2200. So 6000lbs and it did well.
The event was cool, and a lot of cool cars.
The M3 is 1100 hp at the wheels roughly, my m5 is about 750-800 at the wheels and the G63 is stock. so maybe 2500 hp In that photo LOL!
