2019 AMG G63 Question
Hello to All;
I am very happy to be part of the forum. I have been a MB owner sine 2009. Purchased my G63 a few years ago. when purchased it had 24" wheels with P305/35R/24 tires.
I have to make a hard left turn from my alley to the driveway. It started grinding. not rubbing. We removed them and installed the original 22" wheels. When removed, there was a 12MM spacer.
Decided to try the 24" again. Bought some 31MM spacers hoping would stop the noise. That did not work! Could not even get them mounted, hitting the fender. Any suggestions on how the make the tires fit with no rubbing or grinding.?
Hello to All;
@Andyorjill if you can provide some additional information it might help us solve your problem.
- Do you know the specs of the 24" wheel you are running? Mainly need the width of the rim and the offset.
- Where is the grinding/rubbing happening when you turn into the driveway? Ie, the inner side of the tire hitting the downpipes or frame, or the outer edge of the tire hitting the outer fender?
- Is the suspension system on your 2019 G63 completely stock, or has it been lifted or lowered?
The Butcher (10-02-2024)
The G63 is completely stock. The Wheels are Giovanna 24x10 wheels. From what I figured, it has a negative offset of 25MM or 1".
The noise; Outer edge- very little rubbing on the fender well, not fender. Inner,- definitely a grinding noise, possible axel being pushed out?
Just so I understand, you have rubbing in two places, correct? The outer edge of the tire is rubbing on the fender liner, and the inner edge of the tire is rubbing somewhere on the inside? Do the two noises sound different? Ie, there is a slight rub on the plastic wheel liner on the outside edge, but the inner sounds like a grinding noise? Does the grinding noise on the inside sound like metal on metal, or like the tire is rubbing something? If it's metal on metal I'm wondering if the wheel itself is rubbing on something versus just the tire contacting something. Are there any scratches/marks on the inside edge of the wheel? These things are tough to diagnose without pictures and/or videos. If you are rubbing inside AND outside then it sound like you might need to get a different set of wheels or maybe different size tires.
