G Class (W465/W463A) W463 Produced 2019-2024: G550, G63 AMG W465 Produced 2025-
Best Hidden Dash Cam?
Old Oct 20, 2024 | 08:02 PM
sphil305's Avatar
G WAGON
Exclamation Best Hidden Dash Cam?
Hey, I am looking for the best hidden dash cam that I can have wired professionally. I found Fitcamx selling one, but it looks like the back dash cam is visible.
Old Oct 21, 2024 | 11:02 AM
dcarrer0's Avatar
2021 G63; 2018 Aston Martin DB11
I installed the Fitcamx. Easy install & looks factory. Front camera only.
Old Oct 21, 2024 | 11:59 AM
smspragueaz's Avatar
2025 G 550
2025’s have a built in dash cam you can turn on for $200 through the Mercedes Me app.
Old Oct 21, 2024 | 06:39 PM
GforMe's Avatar
G 63
Op, did you also watch
from Queens over the weekend and cringe leading to this post?
Old Oct 21, 2024 | 10:11 PM
deniska's Avatar
'25 G550, '21 911Cab
Was the option required to be installed at the factory for this feature to work?
Also, does it record automatically each time the vehicle starts, or does it need to be activated manually each time?
Old Oct 21, 2024 | 11:36 PM
2025 G 550
Option not required to be installed at factory. Just turn on through the app.
Yes it records 20 minutes segments automatically at start up. Works perfectly.
Old May 26, 2025 | 06:25 AM
TheShockMaster's Avatar
I mounted mine right behind the rearview mirror using the USB-C port in the overhead console for power...stays hidden and starts up clean with no dangling wires.
Old May 27, 2025 | 09:28 AM
Darkest2000's Avatar
'25 G63
Is this for a new G class? The factory built in dash cam for $200 is hard to beat, you only need to provide your own removable thumb drive. Auto start/stop and loop.
Old Jun 5, 2025 | 06:14 AM
I ended up going with the Insta 360 today since it stays tucked up near the rearview mirror and doesn't block any view. I added the optional rear camera, and I might go for another one later. I wanted a clean setup that could capture full road view in 360 and still let me keep everything looking stock from inside the G-Wagon.
Old Jun 5, 2025 | 07:20 AM
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
How did you get the 360 to tuck under? Every image of it I can find it is outside of the car.
