G Class (W465/W463A) W463 Produced 2019-2024: G550, G63 AMG W465 Produced 2025-
Aftermarket Black Running boards?
Old Jul 10, 2025 | 07:38 PM
TheVazha's Avatar
W213 E63
Originally Posted by Trayder
That will look nice and probably be more durable too, I had the front brush bar on my old G63 coated with Line-x "ultra" which delivered a similar finish, it held up perfectly over the 10 years we had the G, most of that in the Florida Keys sun.
The running boards disassemble very easily, the rubber strips slide off as do the end pieces.
Disassembly is as follows (for a 2025 G63 but assume 2019-2025 would be the same):
1: Remove plastic push pin fastener in the front fender well
2: Remove plastic push pin fastener and (1) trim bolt in rear fender wall
3: Remove all the bolts underneath running board, Leave the middle one in place until end so it doesn't fall on your head and you can control its removal, the boards aren't too heavy but are awkward, also wrap the muffler with something as not to scratch it.
The running board will come off as one complete assembly and now you can pull off the front and rear plastic pieces, then slide out the rubber strips (some have difficulty here but I think the newer the G the easier)
that's about all.
Awesome thanks for the write up!
Old Apr 9, 2026 | 05:10 PM
Turbo S's Avatar
2020 G63
Here is a link to the one that showed up: https://www.ebay.com/itm/187171354425 (price went up a touch)
The one that did not show up was the one in my original post "SK Racing".
Thank you for all the information. I would have never ordered these until I read your results. I just hope they don't take 5 months to get here.
