G55 at the drags.....timeslip attached
Ted
Ted
.......launching the G55 is easier than a rear wheel drive car. However, because less skill is involved, it is a bit harder to improve on your 60 ft time. You can't really do a burnout in a full time 4 wheel drive car. This turns out to be a problem, becacuse with the K2, the truck's tires spin off the line if you simply punch it. I have Nitto 305/55/18 drag radials on the truck that I cannot make full use of because they need to be heated up by doing a burn out. My thinking is that to get the truck into the 12's, one does not need addtional low end punch after the K2, rather one would need to improve mid range punch and trap speed. Currently mine has a trapspeed of 104.3mph. An addtional 2mph should easily get the truck into the 12's. Will post results.
Ted
Ted
You have to go through the whole procedure to defeat it completely(losing all the electronic assists in the process)in other words ,go to the dyno mode.
Last Summer did it and dropped from 13.2/104mph (traction on) to 12.8/112mph in dyno mode.
Both runs done at 4:30 am (cool 60s),within minutes of each other ,using G-tech for comparison purposes.
Ted
Ted
thats what i expected! ...but i couldn't get it any lower...also tried power braking etc
In dyno mode you get a perfect launch with lots of smoke and a drop almost 0.5 s in a 1/4 mile.
Ted
Ted
