squeakly door latches
06 E500 sport
Periodically, the doors on the G55 seem to make a squeaking noise. The dealer says the doors need to be "Adjusted" and fix it.
Is this something common?
It's been the Pass front door, then the RR door, now the driver's door. It's a very noticeable LOUD squeak noise.
Also, I'm trying to soften the "hit" over bumps (seem to bottom out, but appears also to be extremely stiff rebound dampening of the front shocks). Maybe that's a cause of the problem of "loosening doors".
The doors close solidly. That's really not the issue. any advice out there?
2013 G 63 AMG
Happens to almost all G-wagens. The doors usually require some adjustment after leaving the factory and being driven for a while. I only had to have this done once. After that, occasional spraying of a lubricant spray by my dealer at every service is all that's required. I'm not sure what they use, but it's a special type of lubricant recommended by MB. Maybe DUTCH or someone else can shed light on this.
My MB dealer in Dubai is FAR from perfect, but one thing they do know is the G-wagen as they have been selling them for twenty years and sell a lot of them. They knew exactly what to do about the squeaking.
06 E500 sport
It actually begins with the squeaking and usually ends up with a door that won't open. I know it sounds strange, but the squeaking has happened to all 4 in 50k miles and two of them have failed to open when they were squeaking pretty badly.
I was curious if perhaps the G55 had more of a problem because of it's inherently rougher ride.
06 E500 sport
2004 360 Spider, 2006 750Li, 2007 G55 AMG, 2008 Bentley GT Speed
there is a silicone liquid available from MB; it's used on the squeaky seals of the "SL" hardtop. your dealer will usually just give/sell you the small (25ml-50ml) bottle if you ask them. get a small thick-bristled paint brush, apply directly to brush and paint over the rubber seals around the 4-doors and the rear door. you won't hear another squeak...until you ned to apply more.
06 E500 sport
The service managers seem so clueless on this. I'll inquire the next time I'm in for service.
thanks again.
no. i have a bottle in my truck. will get the MB code off of it and post tomorrow. as soon as brought my truck down to Florda from Colorado in Jan it started the mind-numbing squeeking again.....a brush of this stuff on the rubber seals on doors and on the door frames.....sound gone.....
The product is "Special Sliding Compound, Lubricating oil". The part number is A 000 989 36 60. It's what MB use on SL roofs to stop the squeaking. Good luck.
