G55 AMG (W463) Discuss the G55 AMG.
AMG Command logo on start up
Old Dec 14, 2010 | 07:18 PM
alroumi's Avatar
G55, G500 & SLK55
Any one done this before ? I had it done on my SLK R171 by doing the same trick that the W211 owners do press turn ignition key to position 1, press radio, button 5(1 sec) , 3( 1 sec) and 7(3 sec) to access other menu to make the AMG logo pop up
Unfortunately my G55 is in PDI,registration so it will take a while to get maybe another week.
Old Dec 14, 2010 | 07:23 PM
Behike's Avatar
2011 G55
Didn't know but still not sure I'd go through the process just to see the AMG logo.
Old Dec 14, 2010 | 07:26 PM
alroumi's Avatar
G55, G500 & SLK55
It is not hard (that is if it works on the G-class)
Old Dec 14, 2010 | 07:33 PM
Behike's Avatar
2011 G55
I'll give it a shot, why not.
Old Dec 14, 2010 | 07:47 PM
alroumi's Avatar
G55, G500 & SLK55
instructions
Turn ignition key to position 1 or 2.
2. Turn on Command.
3. Turn to Radio.
4. Press 5 (continue holding and wait 1 second).
5. Press 3 (continue to hold along with 5 key and wait 1 second).
6. Press 7 (continue to hold along with 5 and 3 keys and wait about 3 seconds).
7. A menu should appear. Scroll down and select "AMG211_ECE" option.
8. Switch off ignition, remove key and leave about 5 minutes before turning on again
Old Dec 14, 2010 | 10:50 PM
mcw's Avatar
mcw
2008 SL 63 AMG R230
hi got a R230 SL63 but cant seem to make it work
fyi R230 way of entering 'hidden menu' are
engineering menu (Hangup, *, 6) ,
Dealer menu (Hangup, 7, 9) ,
restart MOST fibre optic ring by holding Hangup & 2 keys, or
holding the power button for a long time.
can anyone translate the above / share how to enable " AMG start up graphic " in R230 / NTG2.5 please
Old Dec 18, 2010 | 12:05 AM
jimmyg's Avatar
2013 G 63 AMG
instructions
2. Turn on Command.
3. Turn to Radio.
I recommend you don't do this on your G-wagen for two reasons:
- the AMG211_ECE option sets the COMAND system up for operation on a W211 which is the E-Class and you may lose some functionality customized for the G-Class.
- Mercedes has confirmed that their dealers are within their rights to refuse warranty service on your COMAND system if any changes like this are made.
Is it really worth it just to have that logo show up for a few seconds when you start the car? I'll admit considering doing it myself, but honestly in the long run you'll get bored of it and probably end up regretting it.
Old Dec 18, 2010 | 12:08 AM
Behike's Avatar
2011 G55
Good to know. Thanks for the heads up.
Old Jul 2, 2013 | 02:51 AM
Hakop's Avatar
2005 CL55
Any1 know if it's possible to get the Amg logo on startup on a w215 2005 cl55 ?
