G55 AMG (W463) Discuss the G55 AMG.
Kleemann 2003 G55 Project - S/C!!
Old Sep 17, 2012 | 08:32 AM
BonitaBeast's Avatar
2017 G63 Edition 463, 2008 G55k
Finally moving along!
Main Drive belt is on. Fuel System mods are in:
Airboxes installed today:
Test fitting of engine cover:
Few things left to do:
Run air lines, cooling lines, install air pump and relays
Old Sep 17, 2012 | 12:14 PM
xxGenericSNxx's Avatar
99 ML430, 01 CLK55, 07 R63, 15 E63 Wagon
Is the airbox cover an MB part with the Kleemann logo on it or did they make their own piece? The reason I ask is because it looks so similar to a 55K's airbox cover.
Old Sep 17, 2012 | 08:53 PM
I think it's an OEM G55k engine cover with the Kleemann Logo. I put it right next to my brother's G55k engine cover and they look identical.
G55k:
Kleemann V8 (lifted from internet)
Old Sep 18, 2012 | 06:15 AM
Delays delays delays
So close yet so far..... Ever seen a grown man cry???
Talk about frustrating. So I have a few parts missing in the kit. Hopefully the guys at the big K respond quickly. Unfortunately, the soonest I'll have the parts at my door step will be next Wednesday or Thursday; being that I'm about 4,000 miles away from CO. Another week down......
Here's a list of the missing parts:
1.) Plastic t-piece connection
2.) One way valve
3.) kleemann extension arms (that mount to the rubber mounts)
4.) 2 large air hoses into y-connector (attaches to maf from airboxes)
On top of this (pun intended), the engine cover that connects to the airboxes looks like it needs to be modified (meaning I have to cut a chunk out of it for it to fit).
I didn't realize so many modifications had to be done to the existing parts to fit this kit on. It is by no means a direct fit kit. Aaaaaahhhhhhh. Just frustrated. Sorry for venting but that's where I am now.
Time count...... 3 weeks 4 days.
Old Sep 19, 2012 | 02:30 PM
cm60k's Avatar
This oil cooler looks good,, from which model is that....??,
Recently i bought a new oil cooler with hoses from SLK55.....
Kleemann 2003 G55 Project - S/C!!-picture-159.jpg
Kleemann 2003 G55 Project - S/C!!-picture-160.jpgKleemann 2003 G55 Project - S/C!!-picture-161.jpg
Kleemann 2003 G55 Project - S/C!!-picture-162.jpgKleemann 2003 G55 Project - S/C!!-picture-163.jpg
ZAYED,,
Old Sep 19, 2012 | 06:09 PM
Attachment 243864
Attachment 243865Attachment 243866
Attachment 243867Attachment 243868
ZAYED,,
I wonder if this will fit mine. It would definitely make more space for the engine cover. I've seen a CLK500 with that oil cooler and just a little bit cut out from the engine cover.
Here's Kevwood's link with the cutout:
https://mbworld.org/forums/clk-class...-detailed.html
Old Sep 19, 2012 | 06:27 PM
  #32
cm60k's Avatar
The SLK55 is the only N/A Engine with that cooler,, its the based idea of the ALL 55s Kompressor Engines,, the one you have is strange one,,
did you customize it..?, or you bought the car with it......??
ZAYED,,
Old Sep 19, 2012 | 06:43 PM
  #33
ZAYED,,
All the G55's before 2005 (pre G55k) use this oil cooler that I have. It came this way from the factory.
Old Sep 19, 2012 | 06:47 PM
  #34
cm60k's Avatar
I think your right,, cause you have the Vin started with 463.246,, isn’t...!?,
The G55 2003-2005 comes with this type of oil cooler(like yours),, but the MB replaced it to the one from E55K/SL55K/CL55K from August 2005......
ZAYED,,
Old Sep 19, 2012 | 06:54 PM
  #35
ZAYED,,
Yes correct. I wanna look into fitting that newer oil cooler however. Looks neater. Mine looks messy.
Old Sep 19, 2012 | 06:58 PM
  #36
cm60k's Avatar
Is the cooler piece (between the filter housing & the water cooler) has the part #.....??, cause i couldn’t find it in EPC......!!!
ZAYED,,
Old Sep 19, 2012 | 07:09 PM
  #37
cm60k's Avatar
Agreed,, the newer style looks better & more fitment for the cover.....
ZAYED,,
Old Sep 19, 2012 | 07:31 PM
  #38
A 112 188 04 01
Old Sep 19, 2012 | 07:39 PM
  #39
cm60k's Avatar
Thankss for the #s,, but if you notice, the Cooler # & the Housing # for the all ordinary M112 & M113,, they not mentioned the piece
(between the filter housing & the water cooler)......!!
ZAYED,,
Old Sep 19, 2012 | 07:55 PM
  #40
ZAYED,,
I suppose they add the exhanger on the AMG models of the M113 due to higer compression and operating temps so additional oil cooling is needed?
Old Sep 20, 2012 | 06:18 AM
  #41
cm60k's Avatar
MB may replaced this system with External cooler (cooled by air), cause its risky if the Gasket is blown in the cooler,
it well mixing oil with water....!!, like Exactly the idea of the Trans. cooler in the Radiator...,,
what do you think.....??
ZAYED,,
Old Sep 20, 2012 | 09:55 PM
  #42
S/C Install update as of Sept 21
I can finally breathe!
Quick update. I decided to work remotely from the shop so I could check on the install status.
Save for the missing items (Y-connector from air boxes to throttle body and T-Connector for coolant bleeder hose to supercharger bleeder hose), everything is in installed and place. Fuel Pump, Fuel regulator, Water pump, Secondary air pump installed. Supercharger in place. All the relays wired into the fusebox (Fuel Pump, air pump, Water pump).
Minor things left to do:
Install T-connector (Need to wait a week til it gets here!)
Install Y-connector and hoses (Need to wait a week til it gets here!)
Install Kleemann Resistor
Cut away plastic from the engine cover to fit around the oil cooler
Change coolant bleeder hoses to new ones
Change engine mounts
Change tranny mounts
Fit cooling hoses.
Fill cooling system with coolant/water
Problem is I have to wait a week til the T-connector and Y-connector arrive!!! At least this gives me another week to check every single connection over and over just to be sure.
I've heard too many horror stories of messed up installs. I don't want that to be the case here.
No new pics other than actual connections. I don't wanna bore anyone...
Old Sep 20, 2012 | 11:43 PM
  #43
So it looks like the resistor is missing too!!!!!!!!! Will this ever end!???!!!
Would anyone know the value of the Kleemann resistor? I will find one to install.
Old Sep 21, 2012 | 08:33 PM
  #44
patakka's Avatar
W210/W202/W164
Nice modification success with the install
Old Sep 22, 2012 | 02:31 AM
  #45
Thanks.
So the magic number is 550ohms. Apparently the Kleemann resistor is a variable resistor 0-1000ohms. I need 550ohms. I was able to find a fixed resistor at an electronics store and according to Cory, it works perfectly fine; sometimes even better than the kleemann one so that's what I'm going with.
More updates to come.
Just waiting on the T-Connector for the cooling bleed hoses and the Intake Y-connector for the airboxes.
Old Sep 28, 2012 | 05:52 AM
  #46
Last few pieces are going on first thing tomorrow morning. All the missing parts are here and ready to be installed!!
The Resistor went on today. All relays are hooked up. A few more fittings were machined to run the cooling hoses nicely. Those go on tomorrow. Engine cover will be trimmed to fit around the oil cooler tomorrow as well.
I designed a pretty unique kleemann logo scheme. Something I haven't seen yet. I think it'll be understated yet still make a statement; if that even makes sense. Pictures up soon. A little mental preview........ On a G55, think V8 Kompressor. Now imagine, V8 KLEEMANN!! Also, that little red carat Kleemann logo costs a pretty penny but I think it'll look perfect when I'm all done.
Can't wait to start her up!!!
Old Sep 29, 2012 | 08:20 AM
  #47
Badges
So we didn't get to start her up today due to some last minute reconfiguration of the hoses.
The badges did go on though. Here you go......
Old Sep 29, 2012 | 05:03 PM
  #48
cm60k's Avatar
Very nice Badges in very good places......
Great magic touch.....
ZAYED,,
Old Oct 1, 2012 | 05:08 AM
  #49
Filling with coolant as we speak. Wheels are on. Minor fitment issues with the hoses from the airboxes into the Y-Connector. Too short somehow! Doing some magic now.
Meanwhile, the wheels are on and looking Good!!!
Left to do are reinstall grill, headlight housings, underbumper bar, and skid plate. Looks like we do a test start up tomorrow first thing.
Hope she starts up tomorrow!!!
Old Oct 1, 2012 | 12:33 PM
  #50
drew138's Avatar
993 TT
Let's get some video action going! Good luck.
