G55 Transmission Problem! Help :(
Hey guys,
Just hopped into my G55 yesterday after three months,
(driven by someone else untill i was back in dubai) I found out that the car was driven in low gear the whole three months and it got to a point where the car showed a warning that said (TC SET IN NUETRAL) i tried shifting down back to low and the car did not move in 'Drive' and stalled with a horrible sound from right under the engine (i'm guessing the gearbox) so i managed to set in back in TC high with which there are no problems, just wondering if anyone had the same problem and what the problem might be.
2013 G 63 AMG
Ouch...hope they didn't ever engage the diff locks. Get it inspected by a trained mechanic...if its out of warranty then try Silber Arrows in Al Quoz behind Times Square Center. Ask for Philip.
Well what a coincidence, this happened to me last week. I was parking at the supermarket and when I opened the door I got a warning-beep and a dash saying "TC hi lo set in N". From then the car seemed to be in low gear although the H/L sign in the dash display was blank. (Driving there everything was normal)
Tried pressing neutral H/L and nothing but some light clunking from the gearbox area. Drove to the closest dealership (10 minutes) in what seemed low gear, there set it in N and did a L/H switch while the door was open and the signal was beeping, and behold the gearbox showed L and H again and everything seems to work as it should. Drove away and will have to read it out one day soon to see what the problem might be...
@Jimmyg : Thanks for the contact, will go up to Silber Arrows as soon as my brake pads are replaced and i get my baby back. Congrats on the G63 by the way what a beast!
@Sprins : That's exactly what happened, i'm actually really scared to put it back into TC LOW so just going to get it checked out to be on the safe side.
88-300CE TWIN TURBO, 99-C43, 05-G55K, 71-280SL, 94-E320 CAB, 08 CLK63 BLACK SERIES
Possibly the TC control module under the console......
Module has been upgraded quite a few times since the 2003 introduction of electronic control of the transfer cases.
I changed to L/H a few times and drove around quite a bit, and so far no problem (knock on wood).
Happened to me again and made an appointment with them to fix it.
