AAS DEFECTIVE AND AUXILLIARY BATTERY MALFUNCTION
its behind the driver side dash.
http://www.ebay.com/itm/Mercedes-Ben...-/201702075755
please till us if it resolved by changing the trans valve body
I had the following:
P0730
P0731
P2784
P0732
I was also having bad slippage from 2 to 3rd gear. If I turned off truck, it cleared error and limp mode. However, would return often.
Update here after deal looks at the recall.
Appreciate any help thanks.
will keep this thread updated.
THANKS
Hi, quick update so far been around 3 months and touch wood so far so good. No lights or warning have showed regarding the battery.
What the dealership did was they replaced the main 12V battery, the aux and a wire.
But I remember before I gave the car to the dealership before it got sorted I put a multi meter on the main 12V battery and it was measuring 12.3V which is quite low (car was not started) usually around 12.6V is healthy.
Also just as a suggestion for anyone else who has this issue try putting your car on a trickle charger (preferably a good quality ctek one). Or you can try Ctek’s stop start trickle charger.
See attached photo of battery 🔋
ebay better description:
“YTX14-BS Chrome Pro Series High Performance iGel Powersport Battery”
FYI auxiliary battery is located under back seat cup holders underneath main battery.
Dealer told me it was behind the passenger glove box!¿
Hi, I'm having same problem. We replaced the main and the aux but assuming something is either draining or not charging the aux. Do you know what wire was replaced that fixed this? Also, the trickle charger would be just to avoid the main battery from dying, right? Thanks!
the Aux battery is under the main battery. They are both located under the cup holders that sit behind the center console in the rear passenger area floor.
i have both warnings on now.. Is it ok to drive the car until fixed
other thing i noticed is when i switch to Drive, i get a warning " car not in park, may roll" ....Yeah obviously... why would it say that
