Injection Pump Question.
You unscrew like 90 degrees and pull it out and push it in to prime the injector pump
God it has been a long time since I worked on a 240D,
1982-84 working during summers at local indy MB mechanic in a New Orleans Suburb.
that German Josef taught me a lot about MB and cars in general
And yes, the 240D is a classic and a tank - Specially when a Stick.
should last longer than cockroaches if maintained.
PS next time try to keep fuel lines on... Make sure you install new valve cover seal as the old ones get hard and end up leaking. - Part of the job
good luck and post up more pics of car - you have a classic!
peachparts discussion forum has some info about this pump.
This video looks helpful, I didn't watch it entirely.
UPDATE. I did search on the Peach Parts Forum and found out the red cap is indeed for filling the injection pump with oil. There is a plug on the side of the pump that you remove and then flush all of the old oil out this drain with fresh 40wt. oil. When you are satisfied you have flushed it enough wait a few minutes and put the plug back in and you are good to go. There is also a small pipe on the other side of the pump that serves as an overflow in case you put to much oil in. It looks pretty tight access in that area so lots of patience might help :-)
He was back in woods before he opened his new shop on highway 190 service road.
I Learned a lot from him and Billy (I think was his name had the 240Z)
I guess you had to be there.
