General Mercedes Discussion Use this forum to discuss general Mercedes-Benz topics that are not specifically model related.
whats with all the amg posers these days
Old Aug 19, 2009 | 07:26 AM
  #51
walee112's Avatar
2016 GLE400
Originally Posted by CLK Operator
The average Joe does not know the difference between an AMG Benz and a non AMG one. Those that do, know yours is a fake. So what's the point?
i agree with you.. wahts the point. the amg badge is only to impress MBZ fanatics anyways
Old Sep 11, 2009 | 05:35 AM
  #52
Moto_Guzzi's Avatar
2008 C350-Sport-AMG-Active Agility Pack(Not reliable) +Izuzu KB6 3L(It seems Reliable)+Mazda
Wink
Originally Posted by mbenzman
enough. Is there a fashion police for this type of thing?
Yes, heres there badge, but yet has to run into one..
Whatch out for this Fashion Police Car in your rearview mirror.
Old Apr 18, 2011 | 08:35 PM
  #53
who-two's Avatar
sl500 amg-560sl tripple black
hello every one i also own an amg old school 1991 sl500 amg and here in alberta there are so many posers of this amg model and thats ok i now i have the real deal when i hit 185 mph
and shes still got some left .I LOVE HERE VERY MUCH HAHAHA and thats all that matters.
live and let live i always say.
Old Apr 21, 2011 | 12:12 PM
  #54
Improviz's Avatar
CLS55 AMG
There's no such thing as a 1991 SL500 AMG. AMG only produced a few early SL models, listed here:
http://en.wikipedia.org/wiki/Mercedes-Benz_SL-Class#AMG
Old Apr 21, 2011 | 12:52 PM
  #55
who-two's Avatar
amg was a aftermarket company until i think 1993 when benz bought amg.the hammer was one of there first super engines it was a 6 cylinder .and if you really look there were about 765
sl500 amg 6litres produced. i had a head gasket blow and when i took it to a benz mechanic
and after pulling it apart every part that was replaced by amg was scribed with a amg serial n.o .it took me six weeks of emails and phone calls in the middle of the night to get a gasket out of the historical side of benz germany .i got the feeling they just want these old amgs to fade away. but after hounding them they also produced the complete amg parts manual to benz canada. torque specs, parts everthing.so you can phone benz canada now and they can supply you with all the info on this car .cheers
Old Apr 21, 2011 | 01:14 PM
  #56
Improviz's Avatar
CLS55 AMG
AMG signed a joint agreement with DaimlerBenz in 1990 after which all AMGs were to be sold through Mercedes dealerships, but not sure when this actually took effect.
They did produce an SL60 around that time with the 6.0L motor, which I think is what you're describing; they were an SL500 modded by AMG with a 6.0, but afaik they're referred to as "SL60 AMG", not "SL500 AMG", right?
Old Apr 21, 2011 | 01:43 PM
  #57
Improviz's Avatar
CLS55 AMG
Here's an article on an SL60 AMG, but this is newer than yours:
http://www.theautochannel.com/public.../amgsl60.frame
I found some more stuff, it seems that the correct, full name for yours is "500 SL 6.0 AMG":
Over the time the R 129 “SL” have been built, Daimler Benz replaced in June 98’ the Double Twin cam 32 Valve engines oft the M 119 series and the Inline Six’s by V 90° 6 and 8 Types with a single cam per bank and three valves per cylinder. {Type M 112 an M 113}.
All the AMG R 129 built types used the same Identification code of the basic Daimler Benz car design.
The “SL 60” was based on the “500 SL” {R 129.066/.067}, a car, originally fitted with an 4.973 cm³ engine {M 119.960/M 119.972/M 119.982}. There have been built three different AMG Versions of the “500 SL”, but the major changes are the same.
The original crank was replaced by the crankshaft of the M 117.968 {“560”}, means the stroke was increased to 94.8 mm {3 ¾ in.}. The bore was increased to 100.0 mm { 3.94 in.}, so the engine capacity reached 5.956 cm³. Inlet and Exhaust channels of the cylinder heads were extended and polished. AMG exhausts has been fitted.
”500 SL 6.0 AMG”
First conversion to 6 Litre, based on the R 129.066 fitted with the M 119.960 KE engine.
These with Bosch KE engine control reached 374 hp @ 5.250 rpm and a maximum torque of 550 Nm @ 4.000 rpm.
They used the same Four speed automatic transmission {722.353}, Differential ratio and brakes as the 5 Litre cars. The tires, mounted on three-piece AMG rims {8 ½ x 17 ET 18 – 10 x 17 ET 17} have a size of 255/40 ZR 17 – 255/55 ZR 17.
This car have been built between September 91’ and August 93’.
”SL 60 AMG
The second series, built between September 93’ and December 95’ used the M 119.972 LH engine with Bosch LH engine control. Those engines, as those of the “E 60”, reached 381 hp @ 5.500 rpm. {580 Nm @ 3.750rpm}. This series still uses the same Front an rear brakes as those fitted on the serial “500 SL”, also have been changed to a larger diameter.
The automatic gearbox was replaced by the 722.364, still having 4 Speeds.
”SL 60 AMG
The last series was built between have been April 196 and May 98.
Now the M 119.982 with Bosch ME engine control was converted, but the output was unchanged. The gearbox was replaced by the new five speed automatic transmission, rims have had 18” diameter, the size of the tires reached 245/40 ZR 18 – 275/35 ZR 18.
AMG Aerodynamic Body kit have been fitted to all official converted cars.
Of all series have around 300 cars been built.
Edit: here's a link to a manual for one, if you speak German:
http://www.envisionauto.com/images/JAD/JAD-MB2801/AMG%20500SL%206.pdf
Old Apr 21, 2011 | 01:59 PM
  #58
who-two's Avatar
lol .thats what made me think i was ripped of when i bought this car .google it and i think youll find sl500amg does exist ,the sl60 has a amg serial n.o. plate located on the fire wall installed by benz and a sl60 logo on the trunk again this made me think i was burnt on the deal . but no it is what my mechanic says.and the sl500s around here will agree lol.who would mark all those parts amg with exact amg specs.lol his words not mine.
Old May 11, 2011 | 08:24 PM
  #59
Highend's Avatar
C219 CLS / W220 † / W211† / W210 E55 † / W210 Brabus † / Hamann 540i † /
I blame Mr. Jones ( Fletcher ), for starting the big boom of that over here. I remember when I rolled in with my E55 to get it serviced back in 2005/6ish and looking at a bunch of 500's with the AMG badge on the back, then looking at the window sticker and seeing that they wrote with a sharpie, "AMG Package + Wheels" $6,575 add on.
It was WOW back then and its still WOW now that people continue to buy these cars with that mark-up because they think they got an AMG. Like my neighbor, guy thinks he drives an G55 when he has a G500 "AMG", he actually bragged about it to me, but I'm in no position to tell him its not, it is what it is.
Old Jun 3, 2011 | 02:01 PM
  #60
Brau0318's Avatar
Mars Red 2005 C230k, 2001 E320 4matic
Well just another reason to call it the stealership. Thats where the posers stem from. I read a story about a guy trading in a 7 series, it had 760 and v12 badges, got a premium trade in and the dealership looked under the hood to find a v8. Weather or not this was true. It could most definitly happen to an uninformed street buyer.
