General Mercedes Discussion Use this forum to discuss general Mercedes-Benz topics that are not specifically model related.
Key not recognised (keyless go issues) - problem resolved
Old Mar 21, 2012 | 02:05 PM
zberi's Avatar
S350
hi
keyless go was not working, the door did not open using even remote buttons...got wrong almost 4 out of 5 times. but once in the car, usually the gear start button would work, then that stopped working too..though ignition was still working.
I replaced battery...no improvement.
Then idea struck and i found the simple problem and solution: the battery holder was loose!!! so put a small piece of paper to tighten the battery holding and viola .....3rd day and im happy with my keyless go...
BTW i read some post saying put the key in ignition for an hour and it will reprogram itself...i tried that but after 10 minutes realised it is non sense and stopped...(this was before finding the solution above)
s350 - 2005 - 57,000KM
Old Jun 15, 2015 | 03:57 PM
Sphinx144's Avatar
2006 E55 AMG, Alfa Romeo Stelvio Ti Sport
I did the piece of paper battery trick suggested here and now my keyless go works every time when in my pocket!
I highly recommend this to everyone before they go and buy a new key.
Old Nov 17, 2015 | 01:30 AM
SuperChargerE55's Avatar
E55 AMG V8 Kompressor 2004 E 55 AMG Type: 5,439 cc (5.439 L; 331.9 cu in) Supercharged V8 Powe
paper?
Perhabs you could clarify paper in key? Wjat do yo
Old Nov 17, 2015 | 01:33 AM
paper?
Perhabs you could clarify paper in battery trick?
What was the symptoms before also key not regonized or?
I get that only when trying to start with start/Stop button and well doors doesn't open with using the key buttons.
Would give me others some idea what problem is I mean symptoms could you do that? Thanks Bro
