Yet More Horsepower from MB
Source: Autoexpress.co.uk
Thursday 25th March 2004
S69 Ups The Ante In Battle Of The Giants
At the other end of the scale from the A-Class, Merc is building a luxury saloon with supercar performance. As the power struggle between AMG and the German maker's other affiliated tuner Brabus intensifies, the former is working on a new flagship, the S69 AMG.
Producing in excess of 675bhp, the model is set to be the wildest S-Class yet, with a larger-capacity version of the 6.0-litre bi-turbo V12 from the S65 (right). With torque expected to be in excess of 1,000Nm, finding a reliable transmission to handle it will have been difficult - but our sources say engineers have managed to do so. In preparation for the introduction of the newcomer, Mercedes has registered the S69 trademark, along with SL69 and CL69. That means we've got a whole range of flagships to look forward to.
1994 E320
Crazy!
Here's the link to the story, same as what he posted...
http://www.autoexpress.co.uk/?http:/...y.php?id=45273
E500 Black/Charcoal, Appearance and Premium Packages, Keyless Go and Remote Trunk Closer
Originally posted by Noble C320
I think its getting out of hand. they need to spend more time with there quality of materials and build quality rather than having 800 hp.
2004 SL55 AMG
In regards to the AMGs, how about more focus on the handling and lightening of the vehicle? Is Mercedes trying to make the fastest drag car for German bragging rights? A little investment and update in technology like a DVD-based GPS would help, not to mention a 7speed AMG.
1 Post
1997 Toyota Tacoma 4x4
Guest
Posts: n/a
Originally posted by mbtech208
The current 5.0 liter 113-series V8 has only been around since the 1999 model year.
Isnt it the same since the 89 SL500? well a modified version.
When i said same i mean from an HP output. They have actualy lowered it.
1 Post
In what car?
In what car?
Guest
Posts: n/a
The '99 SL500 was the first car with the 5.0-liter new generation V8. The '89 560SL was the old 107 body SL, which had a 117-series V8. The 1990 500SL (129 body) had the 119-series V8, which was also used in the '97 E420 and the W140 S-class. Confused yet?
1 Post
thanks for the clarifcation. you know your stuff! In your opinion which was the best NA V8 they have made... Power, smoothness, and reliablity.
Guest
Posts: n/a
I'd say any of the new 113-series V8 engines are the most well-rounded of the V8s. These include the 4.3, 5.0, and 5.4 AMG engines. If the topic is six-cylinder engines, the new V6s are best in terms of reliability, but the inline-sixes were better in terms of a broad powerband and smooth running.
One more question to you. Would you keep a post 2000 MB past its warranty period? Why and why not?
1 Post
Interesting. Thanks for the feedback again.
marta
I think MB needs to work more on handling and driver feel rather than producing more and more horsepower. What use is 10000 HP if you can't handle or control it?
2002 E55 AMG
Personally I think it's at least even between the M119 and the M113. In what way is the M113 superior to the M119? The M113 is obviously easier to do minor servicing on(oil filter on top and not under airbox), but the M119 has 8 less plugs to change...
The M119 is slightly more powerful given equal displacement between the two engines.
1 Post
The 119 also tends to develop a LOT more oil leaks from numerous areas, and have problems with the camshaft oiler tubes blowing caps off and causing lifter ticking. The 113 also feels smoother and more refined. Drive a '97 E420 and a '98 E430 back to back, and there's a huge difference.
2002 E55 AMG
Doesn't the M113 have a larger torque band than the M119? The M119 has 90% of its torque available at 1500 RPM, but it doesn't feel so starting off in second gear...
