722.9 transmission adaptation?
Does anyone know if anything other than STAR can do the 722.9 transmission adaptation? I'm talking about the adaptation in the TCU where the programming makes up for the wear/slack. As I understand it, this is different than the shift point learning for driving habits. If you rebuild, which I'm doing, you're supposed to reset or obviously you'll wear out your friction disks instantly (since it'll think the thinner old ones are in there).
I know I could go to the stealership, but if an iCarsoft MB II or similar can do the deed, seems like a less expensive option.
Thanks in advance!
