General Mercedes Discussion Use this forum to discuss general Mercedes-Benz topics that are not specifically model related.
Certified Pre-Owned 2013 E 350 question
Old Aug 29, 2019 | 12:24 PM
KarlaCalt's Avatar
MB 2013 E350
Hello all! I'm hoping to get some clarification on a problem I am encountering with my Certified Pre-Owned 2103 E 350 purchased at my local Mercedes Benz dealership. I purchased the car at one dealership in November 2018 having 35K miles on the odometer and the car had its first service "A" at a different dealership this past week having 44K on the odometer. I have driven the car approximately 9K miles in nine month's time and I drive very gently as most times I'm carting around my two young children. The servicing dealership went through it's normal inspection process during the "A" service and came back telling me I need rear brake pads immediately as they are worn down to 3 mm. They charge $570 for replacement of rear pads and rotors. I'm questioning how this is possible considering I've only put 9K miles on the car and in order to become a CPO (by Mercedes' own definition) the brake pads must have greater than or equal to 50% of their life left? I'm not sure exactly how to handle this and wondering if I have any recourse whatsoever with the dealership who sold me this car? Is it possible to wear down that much rear brake pad within 9K miles? Thank you for any input or advice.
Old Aug 29, 2019 | 12:58 PM
Mr. Toad's Avatar
2016 E400 Coupe (C207)
The CPO process is more of a theory than a reality. Over the years, I've purchased three CPO BMWs and one CPO Benz (my current car). The alleged and highly-touted "multi-point inspection" doesn't really happen in most cases. The only real value of buying CPO is the guarantee that a dealer will have to fix any problems that YOU discover (they rarely actually identify and address problems prior to putting a vehicle up for sale). In your case, the challenge is getting them to address something that is considered a maintenance issue (as opposed to a failure). If your CPO agreement states that the pads must have at least 50% remaining life at time of sale, I'd say your best chance of obtaining any satisfaction is to go to the original dealership (meaning the one that sold you the car; your servicing dealership isn't likely to help) and complain that the pads should've been replaced prior to certification. They may offer to pay 50% of the service charge as a "good will" gesture, and that's probably the most you can hope for. Good luck.
Old Aug 29, 2019 | 01:05 PM
KarlaCalt's Avatar
MB 2013 E350
Thank you very much for your reply Mr. Toad. The MB CPO buying process has opened my eyes to the fact that I should have had the car inspected by an independent mechanic prior to purchasing. Thinking this wasn't necessary when dealing with a CPO at a Mercedes dealership was extremely naive on my part.
Old Aug 29, 2019 | 01:12 PM
Mr. Toad's Avatar
Don't feel bad, you're hardly the first to fall victim to the CPO sales ploy. Just prior to purchasing my current vehicle, I purchased a very similar example from another dealer. While inspecting the car prior to the test drive, I inquired about what appeared to be paint overspray on the top edge of the grille and the salesman dismissed it as nothing to be concerned about. When I got the car home, a closer inspection revealed that the front end had sustained some type of damage that required the entire hood to be repainted. I called the dealership immediately and told them that I was driving it straight back to them for a full refund.
Old Aug 29, 2019 | 02:12 PM
ygmn's Avatar
2015 E400 Sedan
CALL MB and complain.
Old Aug 29, 2019 | 02:16 PM
KarlaCalt's Avatar
MB 2013 E350
Did you get the refund or what happened?
Old Sep 17, 2019 | 10:28 AM
mmgrad's Avatar
W213 '17 E43 ///AMG - W211, W208 no more
I recently bought a CPO Benz and I tried very hard to get the full service report during the CPO process but the advisor was very reluctant to give me a print out due to some internal service & dealer codes he was worried he couldn't release. I just wanted a line item service record (not the CPO checklist of what was done and was pass/no-pass) of everything done and measurements taken so I know what I was up against regarding wear & tear items.
Thankfully, in the CPO process, they replaced all 4 brake pads, rear rotors and rear tires. Front tires were pretty close to new as well.
Regarding brake pad wear, the rear brakes aren't as thick and hefty as the front and new is only about 8-10mm thick (fronts are about 12mm). So, if when you bought it and it was >50% at 4-5mm, its foreseeable that you wore it down another 1-2mm over 9K miles of driving. Heavy stop-and-go traffic we wear out brakes more. But I would start with insisting you get the CPO report with measurements if you feel strongly that the rear brakes should not have worn out that fast if it truly was over 50% when you purchased it.
Brakes are one of the easiest services to perform as a DIY or from an independent shop. Perhaps check with an independent shop if you don't like the dealer prices....
Old Sep 17, 2019 | 10:50 AM
KarlaCalt's Avatar
MB 2013 E350
Thanks for your reply and helpful information. I ended up taking the car back to the service shop at the dealership where I purchased the vehicle. The shop measured the rear brake pads and tell me they measured 4 mm and I should be fine for another few thousand miles or so before they need replacing. Seems the dealership that wanted to replace the brake pads was jumping the gun in order to make a sale. I've learned quite a bit in this process and that you can't really trust the dealership's service department when they insist you need this or that done to your car. Being a trusting individual and incapable of measuring or knowing these things myself, I believe them when they tell me my car needs something. I've learned to go more by my car's maintenance manual and to possibly get a second opinion before any expensive work is done. I will also treat any vehicle I purchase, CPO or not, much differently in the future knowing that the CPO process seems to be very "fluid" to put it nicely. Knowing the status of these maintenance items that are not covered under CPO warranty could certainly work in my favor when negotiating price.
Old Sep 17, 2019 | 01:02 PM
ygmn's Avatar
2015 E400 Sedan
YOur dash has a warning light when pads need replacing.... as a sensor is "plugged" into pad and when it hits rotor is grounded out and a brake pad light is lit up on dash....
Time to get them changed then.
Also I suggest turning off Lane Keeping Assist as it uses rear brakes to pull car into lane as required if you have it... which wears out brake pads etc.
Old Sep 17, 2019 | 03:05 PM
mmgrad's Avatar
Not to try to 'defend' the stealerships or anything, but sometimes they tell you something "needs" to be changed, what they sometimes mean is, you will need it done pretty soon and that part won't last til your next service appointment. So, rather than have you come back in in about 2 months, they suggest that service be done now while they have your car.
ygmn
This is true. However, this sensor is only on one wheel per axle if the left and right side are wearing unevenly, that could too late. But, don't fret. Even without the electronic brake pad wear sensor, when the brakes need to be changed, you will hear it squeal. Brake pads have a built in metal flap that indicates its time to change. When it wears down to that level, it will present itself as a screeching sound when you apply your brakes.
Old Sep 17, 2019 | 11:00 PM
chassis's Avatar
2017 GLE350 4MATIC
Dealerships are in business to make money. The service department is a 50% margin, and higher, profit center. They sell whatever they can, whenever they can, to whomever they can. Being in possession of this information is helpful to consumers.
Old Sep 18, 2019 | 08:57 AM
Mr. Toad's Avatar
I did get a full refund, and I took back my BMW, which I had traded in. They wanted me to pay them for having done paintless dent removal on a very small body imperfection on the BMW, but I refused because they shouldn't have done anything to my trade-in until their 5-day, no questions asked refund period had elapsed.
