General Mercedes Discussion Use this forum to discuss general Mercedes-Benz topics that are not specifically model related.
2021 GLB 250 — Engine Seized, Warranty Extension Denied Due to ‘Missed Maintenance’?
Old Jun 19, 2025 | 07:37 PM
NinaM's Avatar
2021 GLB 250
Hi everyone,
I need some advice and to see if anyone else has dealt with this.
I own a 2021 GLB 250 with about 81k miles. It had the M260 engine cylinder head/exhaust valve defect, which is a known issue — Mercedes even sent out a warranty extension letter covering this defect for 15 years or 150,000 miles, regardless of ownership.
Here’s my situation:
  • Mercedes was test driving my car after a repair, and the engine seized and failed on their watch — not mine.
  • Now they are refusing to fix it under the warranty extension.
  • Their excuse: the previous owner allegedly missed some maintenance — but they won’t provide any proof of which service was missed or how that caused the valve defect.
  • My understanding is that the defect is a design flaw, so missed oil changes by a prior owner shouldn’t void this special extension.
I’ve asked for:
✅ Proof of what service was missed.
✅ Technical explanation of how that caused the failure.
✅ Written documentation — so far they haven’t given me anything solid.
Has anyone here dealt with Mercedes denying a warranty repair like this due to “missed maintenance” on an obvious factory defect?
  • Did you win it through the dealer?
  • Did you have to file a Lemon Law or Attorney General complaint?
  • Any tips on how to push back?
I really appreciate any advice, similar stories, or contacts you might have — I want to get this resolved fairly and not pay out of pocket for a defect Mercedes admits exists.
Thank you so much for reading and helping! 🙏
Old Jun 19, 2025 | 08:17 PM
smiles201's Avatar
2023 E 450 Sedan. 2018 GLC 300. 2013 E 350 Coupe (retired)
You don't want to have to think about lawyers, that is a long perilous road. Do you know previous owner or have any way to contact for previous records? They don't know for sure that previous maintenance was missed. But they are holding the cards. Up to them to say if they going to cover you or not. Is there a state consumer protection agency? If all else fails, ask mbusa for a generous credit for a new purchase. Perhaps an indy could find a rebuilt engine for you. Sorry to hear this and wish you luck! There is a solution that will become clear.
Old Jun 19, 2025 | 08:18 PM
superswiss's Avatar
2019 C63CS
I haven't dealt with this, but firstly, all warranties are limited warranties and missed maintenance can lead to denied warranty claims. They do have to show that the missed maintenance resulted in the failure, in order to deny the warranty.
However, the cylinder head extended warranty for the M260 is about worn valve seats, which in itself does not cause an engine seizure. Rather it leads to inefficiencies, compression and performance losses, misfires and rough engine, but seizure of the engine it doesn't cause unless the valve brakes off, but you'd have to ignore the misfires etc. for a very long time before the valves wears out so badly that it brakes off. So, the engine failure is very likely not related to the defect the extended warranty covers.
Also, even though it is a known issue with the M260 engine, these known issues never affect a 100% of the engines, especially if the engine has been properly maintained. In the absence of proper maintenance, there's reasonable doubt that the missed maintenance contributed to the engine failure. You can try to fight it, but likely will face an uphill battle, because as said, the defect the extended warranty covers does not really result in engine seizures.
Old Jun 19, 2025 | 08:41 PM
NinaM's Avatar
2021 GLB 250
Thank you — this is really helpful and lines up with what I’ve found too.
Here’s what’s confusing in my case:
  • My GLB’s original issue was exactly the worn valve seats in cylinder #4 (which the extension covers).
  • Mercedes replaced the cylinder head, then while THEY were test driving it, the engine seized — they say it’s because the bearing in cylinder #4 locked up.
So technically, the same cylinder that had the valve defect is where the bearing failed, and it only failed after they repaired the head.
Now they’re denying coverage because they say the first owner missed some maintenance, but they haven’t given me any proof or clear cause-and-effect explanation.
I get that a valve issue doesn’t always seize an engine, but if they’re linking the bearing failure to lack of oil changes, they need to show it in writing — so far they haven’t.
I’m pushing them for this and considering Lemon Law if they won’t back it up properly.
Old Jun 19, 2025 | 08:42 PM
NinaM's Avatar
2021 GLB 250
Old Jun 19, 2025 | 09:51 PM
superswiss's Avatar
2019 C63CS
A failing cylinder bearing wouldn't be related to replacing the cylinder head. The bearing is on the opposite side down in the crank case. Problem is always that once work is done on something as complicated as an engine, something else that was close to failing could coincidently fail when the engine is opened up. A cylinder bearing locking up can definitely be a sign that there was insufficient lubrication at one point. You can ask them to show you the failed bearing. Assuming they are not lying and the bearing indeed failed then I would say they have a pretty good case blaming it on missed or improper maintenance by the previous owner.
Old Jun 20, 2025 | 12:06 AM
smiles201's Avatar
Don't know about auto engines, but in an aircraft engine, if you replace one cylinder head incorrectly, it can result in a spun bearing and bearing failure. May be coincidence or as ss says, but they should pay for at least part of this as they had the misfortune of it failing after they touched it, a more proximal cause than the somewhat nebulous theory of poor lubrication in the past, which might indeed be the true cause. Need a meturalogic post mortem! At the least they could have warned you about the danger of the procedure and had you sign a release.
Old Jun 20, 2025 | 12:28 AM
Highline-Autos.com's Avatar
SPONSOR
2001 E55AMG
Yes they need to show you what maintenance is unaccounted for, unfortunately because dealers do not share service information beyond the Car Fax... this will be pretty easy for them. I'd gather as much records as your can, and try as hard as you can, and if you have to, try the dealer on the other side of town.
Trenton O. Gibson
tgibson@highline-autos.com
Highline Autos
Direct: 602.909.9216
Office: 480.348.0777
Old Jun 20, 2025 | 03:53 AM
ygmn's Avatar
2015 E400 Sedan
But maybe their mechanic forgot the oil and drove it... or did something wrong.
Make them prove they did not cause issue because it happened while they had the car not you.
They need to prove it was not their fault first IMHO.
