GL450 Issue
Old Nov 14, 2006 | 06:01 PM
Cedric1031's Avatar
2007 E63 AMG
Smile GL450 Issue
Hi,
Got my GL450 blk/blk couple weeks ago. There is something I would like to share. Not sure if a known issue or just the car was built this way.
My GL450 has keyless go entry. Try this. After you stop the car, leave the gear switch to "D" mode. Press the 'STOP' button. The engine will actually just STOP and while you are in "D" mode, the car will slide like in "N" mode. I tested it on up hill, so my GL slide backyards.
The reason I want to bring it up cause my other 2003 E500 keyless go entry acts totally different. While your engine is on, and in "D" mode. Even you try to press the 'STOP" button, The display will show in RED, telling you that your car is not in park mode or something. So you can't really press the stop engine button while you have the gear swift to "D".
Just curious cause it acts little different. I javen't tried to use the actual key to turn it off.
Old Nov 14, 2006 | 06:21 PM
D2-AUTOSPORT's Avatar
Former Vendor of MBWorld
VIPER
Sorry about your issue, but DAMN thats a nice shine in the pic!!
Old Nov 14, 2006 | 06:30 PM
Cedric1031's Avatar
2007 E63 AMG
GL450 Issue
Yes, but I am not sure if this apply only to my GL450 or others are the same. I will need to goto the dealer and find out.
If someone has the same issue, please share with me.
Old Nov 14, 2006 | 11:24 PM
Kar don's Avatar
Mercedes-Benz
are you sure? It should roll a little bit but the park mechanism should catch. Pressing stop while in D is supposed to automatically engage PARK, u have to press the brake pedal and be at a dead stop tho.
Old Nov 14, 2006 | 11:43 PM
TeutonicCarFan's Avatar
2001 VW Jetta GLX VR6
Sorry about the KG issues, i don't have to worry about them with my regular key ignition. Regarless, the paint on your GL looks like GLASS, what do you put on it? Also, the paint color on your 996 is AMAZING
Old Nov 15, 2006 | 12:58 AM
Cedric1031's Avatar
2007 E63 AMG
GL450 Issue
Hi TeutonicCarFan, That is just metallic black color. My 996 is Seal Grey.
Old Nov 15, 2006 | 01:02 AM
MB Fanatic's Avatar
4 wheels
Your GL is Obsidian Black aka Metallic Black
Old Nov 15, 2006 | 01:10 AM
Germancar1's Avatar
2013 650i Coupe, 2010 IS250 AWD, 1999 S500
That GL surely is glossy. Someone has been working their a__ to get it looking that good. Black is the worst color to maintain, but nothing shines as good when it is clean.
M
Cedric1031's Avatar
2007 E63 AMG
GL450 Issue
Hi Kar don,
The reason I notice that the car sliding backwards is I parked my car up hill, When I got to my office, I stop the car, but by accident I thought I push the button to "D" but I didn't. I then press the STOP button, when I let go the brake, the car went backwards, it didn't engage the Park Mode. I think I need to do a video to show you guys hehehe.
Old Nov 15, 2006 | 01:11 AM
Cedric1031's Avatar
2007 E63 AMG
GL450 Issue
Yes, It is Obsidian Black. Sorry about that. hehehe.
Old Nov 15, 2006 | 01:13 AM
Cedric1031's Avatar
2007 E63 AMG
GL450 Issue
Did you try that on yours?
Old Nov 15, 2006 | 02:22 AM
Kar don's Avatar
Mercedes-Benz
i dont own a GL, but the new S-class has the direct select as well and u can just hit stop while in D. Same with the R-class. I would assume the same is for the GL. The cars do roll back more than others i have noticed, did you try letting off the brake slowly to see how much it rolls?
Old Nov 15, 2006 | 10:51 AM
blazinginder's Avatar
AlabasterWhiteSL ObsidianBlackML
my 2005 SL has keyless go and it shows a red warning screen if you try to shut it off in any gear other than park...so i'd assume that would be the same for all other MB's with keyless go...I'd take it to the dealer and have them check it out
Old Nov 15, 2006 | 12:54 PM
Could we possibly get a picutre of the p-car with the MB? For my wallpaper
Old Nov 15, 2006 | 12:59 PM
Cedric1031's Avatar
2007 E63 AMG
GL450 Issue
Hi Blazinginder, Yes this is correct. On my 2003 E500 keyless go, it will show a red warning also. But not on the GL450. I just post a video that I did this morning to show you guys.
Old Nov 15, 2006 | 01:25 PM
I believe the GL should be the same, due to safety reasons but maybe im wrong
Old Nov 15, 2006 | 01:27 PM
Cedric1031's Avatar
2007 E63 AMG
GL450 Issue
I would assume they should all act the same. But it just won't show me the red message. Did you see the video I posted?
Old Nov 15, 2006 | 05:05 PM
AsianML's Avatar
2007 E63
It doesn't happen on the SL nor the E because of the traditional gear shifter. Since the GL is electronic, it can put itself in park on its own now, and you won't get that warning.
Old Nov 15, 2006 | 05:09 PM
Cedric1031's Avatar
2007 E63 AMG
I don't know if this only happens to Mercedes , cauuse BMW 7 series using the same electronic gear shifter, they will not allow you to stop the engine while in "D" mode.
