Ride Height Override
Old Mar 3, 2007 | 03:04 AM
2thfixr's Avatar
Depends where I'm going.
I was wondering if anyone knows how to override the airmatic ride height system to stay raised? I haven't quite figured it out yet but it seems that 40mph+ for a certain amount of time causes the system to drop down to the lowered level and as soon as you hit 50mph, it drops immediately. When I am in stop and go traffic, I like to raise the car because it's nice to see over traffic but the system always lowers me automatically during the brief moments when traffic lets up. I see the reason for lowering but it would be nice to override.
Old Mar 3, 2007 | 08:48 AM
Bax's Avatar
Bax
2007 GL450 Capri Blue
Plus it just looks better when raised!
Old Mar 3, 2007 | 12:52 PM
Abscam's Avatar
3/30/07: B/B GL450 01 319 323 324 334 396 550
3 words
Off Road Package
Old Mar 3, 2007 | 01:23 PM
2thfixr's Avatar
Originally Posted by Abscam
Off Road Package
Off road package lets you keep ride height raised above 50mph?
Old Mar 3, 2007 | 03:15 PM
esport's Avatar
08' S550,,,C63!
I also like to know how to keep the ride height set to the raised level at all times without have to worrry if I pass 40mph.
Old Mar 3, 2007 | 03:33 PM
Stoneseller's Avatar
'13 ML350 Bluetec for work, E550 for pleasure, & ML350 for my wife
I have the off road package. Elevated to the highest setting it stands tall like a Hummer , don't think anyone would drive around on the streets like that.
If I RTFM correctly, the vehicle will lower itself even with the offroad heights engaged. I have yet to try & see.
EDIT Just looked at the manual again. If in height 3, warnings go off @ 20 mph, and vehicle lowers to height 2. If at height 2 & speed maintains between 40-55 for more than 20 seconds, it goes down to 1. If in 1 or 2 height & speed reaches 55, it goes all the way down.
Old Mar 3, 2007 | 05:35 PM
lrrp's Avatar
two words
you can't
Old Mar 3, 2007 | 11:23 PM
Abscam's Avatar
Sorry - talking out my **** - as I am not in possession of my GL at this piont.
I'm sure you can get some dude from the hood to install some hyraulics and get all the height you want. It would be a pretty stiff ride though. The vehicle drops down for aerodynamics
Likely you could find some fuse that would overide the low-ride.
Old Mar 4, 2007 | 05:01 AM
2thfixr's Avatar
Sounds to me that you should be able to clip a speed sensor wire. Anyone have schematics?
Old Mar 4, 2007 | 04:54 PM
oknish's Avatar
'07 GL 450, '02 S 80 T6
And while you are at it, change the RSE wiring to plug your video feed (red cable on the MOST harness) to your head unit video display so you can watch movies while driving.
Old Mar 4, 2007 | 08:25 PM
2thfixr's Avatar
Not crazy at all, I performed this very mod on my 2007 GS350 without issue. I clipped the parking brake sensor wire and speed sensor wire that feeds the DVD player and now the nav screen plays DVDs while in motion. All I need are schematics and it will be done. DVD video on the GL's nav screen would be different though as the US nav screen probably has to be swapped out with the Euro system. As far as the ride height issue, it's just a vehicle speed sensor signal which can easily be clipped or better yet an inline switch can be added to trick the car into thinking that it is not moving and therefore not lower the car. Very easy hack once schematics are located.
