Daylight saving time
OTOH, the fact that you can change the time zone, but not the time, tells me it should change automatically. Why else would it need to know the time zone? It must calculate the time as a variation from GMT off a satellite based on the zone you've manually entered.
Truly great would be an integration of the nav and the satellite. The nav knows where you are, therefore the time zone, and would adjust when you enter a new zone on the fly!
That's weird. I picked up mine in CA and had to go in to COMAND to change the time zone. It was set to Eastern time zone and stayed there for a whole day till I changed the timezone manually.
If your vehicle is equipped with the Modular COMAND System (Cockpit Management and Data system) and navigation module, the clock is set automatically via the navigation module. To manually change the time setting, press the Serv button and adjust the time with the Time soft key.
Dear Dan,
We regret that our prior email did not direct you to the clock change instructions for your Mercedes-Benz.
In an effort to assist you with setting the clock on March 11th, we've included instructions below which are applicable to most models. If you're still having trouble setting the clock, please refer to the detailed instructions for your specific model and year in your Operator's Manual.
Depending on your vehicle model, clock adjustments may be performed through your instrument cluster, steering-wheel controls, or through your vehicle's COMAND system. Scroll down to find the instructions for your Mercedes-Benz.
Setting the clock using the multifunction steering wheel — vehicles without COMAND
With the engine running and car in Park, press the Page button (lower left side) on steering wheel until Settings appears in the lower display of speedometer. Do not press Reset at this time.
Setting the hour:
Step 1
Move the selection marker with the + or - button to either the Set Time or Time/Date submenu.
Step 2
Press the /\ or \/ button until the message Time Hours appears in the multifunction display. The selection marker is now on the hour setting.
Step 3
Press the + or - button to set the hour.
Step 4
Press the Reset button in the instrument cluster to confirm the settings.
Setting the minutes:
Step 1
Step 2
Press the /\ or \/ button until the message Time Minutes appears in the multifunction display. The selection marker is now on the minute setting.
Step 3
Press the + or - button to set the minutes.
Step 4
Setting the clock using the COMAND controls
Step 1
Press the SVC button.
Step 2
Highlight and select System Settings by rotating and clicking the rotary knob.
Step 3
Highlight and select Settings.
Step 4
Highlight and select Date/Time on the settings menu and press to confirm. The menu displays the date and the time with the minutes highlighted.
Step 5
Press the right-hand rotary/button (on newer systems, use the arrows to select minutes or hours). When setting mode is active, the minutes will be highlighted.
Step 6
Turn the right-hand rotary/button to the right. Each click or press will move the time ahead in one-minute increments (on systems without a rotary knob, the up or down arrow is used to adjust minutes or hours; with GPS reception, the time is changed in 30-minute increments).
Step 7
Turn the right-hand rotary/button to the left. Each click or press will move the time back in one-minute increments (with GPS reception, the time is changed in 30-minute increments).
Step 8
To exit the system, press the Back button or hold the rotary/button for more than two seconds (on newer systems press the Back key or OK to save your settings).
Setting the clock for vehicles without COMAND and without GPS
Step 1
To set the hours, pull out the right knob in the instrument cluster and turn it counterclockwise.
Step 2
To set the minutes, pull out the right knob in the instrument cluster and turn it clockwise.
Step 3
To set the clock by a single hour or a few minutes, turn the knob a few degrees in the direction indicated for hours or minutes.
Further Assistance
If you have difficulty setting your clock, please refer to your owner's manual or phone the Customer Assistance Center at 1-800-FOR-MERCEDES (1-800-367-6372).
Funny. My profile title on my other board is "mathemagician."
