hissing noise
Old Jun 1, 2007 | 11:52 PM
Underwhelmed's Avatar
BMW X5, GL450, Saab 9-3, E550
hissing noise
New GL450 (1200 miles) has been making a hissing noise after the engine is turned off and you exit the car. Today it made the noise right after the valet handed it over.
The hiss is brief and sounds like a quieter version of a semi-trailer's brakes.
Anyone know if this is normal for the airmatic suspension or if I should have it checked out at the dealerhip?
Old Jun 2, 2007 | 12:07 AM
abcdef's Avatar
2022 GLE 350; 2016 BMW 428i gran coupe; 2014 Audi Q5 tdi
This is normal operation. Drive on . . . do not stop at the dealer
Old Jun 2, 2007 | 12:27 AM
boxboss's Avatar
The initial builds of the GL had airmatic compressor issues, but those were quickly dealt with. What is your build date?
Old Jun 2, 2007 | 01:09 AM
build date was early may this year
Old Jun 2, 2007 | 01:48 AM
Newbie_2_MB's Avatar
2014 GL 450
I have the same sound with a January '07 build date. Kind of sounds like a big sigh coming from the vehicle.
Old Jun 2, 2007 | 10:32 AM
oinick's Avatar
2007 GL 320 CDI, 2008 M5
Cool
The sound you hear is normal. It is the airmatic adjusting itself. Actually the car will adjust itself even if you come to a stoplight and get slowed or stopped. The car will raise and lower itself as it is programmed to do.
You will get used to it, just like having your wife hiss at you when you say something stupid.
Old Jun 2, 2007 | 03:40 PM
2014 GL 450
Ah, a man who is well-trained
Old Jun 2, 2007 | 05:12 PM
AsianML's Avatar
2007 E63
Are you here to keep the GL guys in check?
Old Jun 2, 2007 | 05:16 PM
2014 GL 450
A girl's gotta do, what a girl's gotta do
Old Jun 2, 2007 | 06:32 PM
str8line's Avatar
00 BMW 528it, 03 Duramax, 07 GL320
Mine makes that sound when I close the door. I wonder if it's air being released from the interior?
Old Jun 2, 2007 | 09:27 PM
blittle's Avatar
2013 GL450 (traded for 2015 Escalade), 2012 Corvette, 2014 Ford Fusion, Previous: 2007 GL450, 2011
Actually, the vehicle will do this quite frequently if you open and close the doors or the tailgate ( engine running or off ) If you watch closely, you can see the front or rear going up or down. Perfectly normal.
Old Jun 4, 2007 | 10:09 PM
AutoSaurus's Avatar
1997 E320 Sedan
I believe it was carprsn who described it as a hot frying pan with water poured on it!
It is normal and it happens not only when exiting, but also while in motion. I heard it several times just today.
Old Jun 5, 2007 | 11:10 AM
Jack450's Avatar
GL450
I have a Jan. '07 build date. Initially started noticing what seemed to be a front end suspension problem in that it would make a "thud" noise going over even small potholes, etc. Thought it was just me or it was the low profile tires. Just recently it showed a Malfunction Symbol Message on the Multifunction Display. The symbol is a pic of the GL with an arrow pointing up. Took to the Memphis dealer(not where I bought it). Two days later back in business. Advisor said they replaced the compressor and that they have seen this problem before. Did not want to give back the C230 Sport loaner. What a fun little car!
Old Jun 5, 2007 | 11:13 AM
StevethePilot's Avatar
2004 RX330, 2008 Scion xB, 2001 Honda Insight Hybrid, 2010 Toyot Prius v ATP
C230 Sport! You lucky son of a gun. Phoenix Motor gives out plain C230's, the cheapest they've got. Not that I mind still driving a Merc, but PLEASE! A Sport!
Old Jun 5, 2007 | 11:22 AM
AutoSaurus's Avatar
1997 E320 Sedan
I just reported to NevadaJack last night that I am hearing this very sound also! I can't pin point where it is coming from other than the front right side and it mainly happens while traveling over rough roads, etc. It doesn't happen all the time but its happening more often now. To me it sounds like a door not closed all the way. I've receive no error messages and the air suspension seems to work just fine so far.
Old Jun 5, 2007 | 11:44 AM
Jack450's Avatar
GL450
Sound like you may need to get it checked out. By the way, some guys who own big trucks tell me that it's not too uncommon that a turbo hose will blow off after taking delivery of a new truck. And like I had mentioned before, I have an '05 Ford diesel that done it 4 or 5 times. I think they fixed with two clamps, cleaned it with brake cleaner and some type of adhesive.
Old Jun 5, 2007 | 11:52 AM
Nevada Jack's Avatar
2011 E350 Cabriolet..White and Almond Mocha
After reading Jack450 post...I thought of what you mentioned last night Jack. Seems like a similar situation...
Old Jun 5, 2007 | 12:24 PM
AsianML's Avatar
2007 E63
Does the thud sound like a dead body rolling around in the trunk?
Old Jun 5, 2007 | 02:15 PM
ksdprasad's Avatar
2007 GL450, 2006 Porsche 911, 2004 VROD
That is normal. GL programmed to adjust air suspension only when the doors are closed.
Old Jun 6, 2007 | 12:30 PM
Does it sound like a Youper locked in a box?
Old Jun 6, 2007 | 12:59 PM
AsianML's Avatar
2007 E63
Geez, I was wondering because E-Class Airmatic folks have experienced the same noise.
Old Apr 12, 2016 | 12:16 AM
sylviap's Avatar
2013 GL450
Hello. Bought a 2013 GL450 4matic as CPO w/ 31,000 miles almost 2 weeks ago. Just noticed a brief screeching noise after the car is turned off. Some of the earlier posts from above say it's a "hissing" sound. Sometimes the screeching noise happens and sometimes it doesn't. Can anyone tell me what this problem might be? Other than that it is a really nice ride! Thanks!
