Two questions on GL
best product to clean wheels is soap and water with a brush...or you can use any type of wheel cleaner found at your local pep boys, advance, etc, then use the soap and a brush...
That is so tech-geeky.
I am so going to give that a "check this out" when the weather's better here.As for opening all windows and the sun roof, you can use the "normal" key (if you can call it that) do it that as well. You don't need to have "keyless go."
My advice...after washing the GL, use a second mitt (I use a newer one for the paint and when it's old, rotate it to tire duty and get a new one for the paint) and use the wash solution for the wheels and tires. Regular washing with car wash and a mitt and you will not need a specific wheel cleaning product. I prefer the lambswool mitts. The cheap ones at Wal-Mart, etc are just that - cheap and shed a lot of fibers. The ones at AutoZone, Advance, etc are not that much more expensive and are of a much higher quality.
