I hope you NEVER have to get to the battery!!!
Old Sep 13, 2007 | 01:59 AM
FCO's Avatar
FCO
08 GL 550, 07 Porsche GT3, 07 SL 550, 06 CLS 55, 06 Lamb Gallardo SE, 06 HD Fatboy, 06 HD RoadGlide
In the process of hard wiring my V1, I accidently shorted things. I blew a fuse immediately. Started looking for the blown fuse. They all looked good (the ones by the passenger door, the ones in the engine compartment, the ones on rear cargo area), so I started to look for the battery. Guess where they put it? Under the passenger seat. You have to cut the carpet, remove the rear foot vent and guess what, there are more fuses by the battery. Found my blown fuse. 30 amp fuse, but what a pain to get to the fuses and battery. I gave up on the V1, I'll let the dealer install it.
FCO
Old Sep 13, 2007 | 06:54 AM
jpeardm's Avatar
13 SL550, 14 E63 Wagon, 15 S550, 11 M3, 08 F430 Spider, 12 ML350
Kinda like working on the Space Shuttle.
Old Sep 13, 2007 | 10:24 AM
FCO's Avatar
FCO
You better instructions on a shuttle with pictures and the manual is in English.
Old Sep 13, 2007 | 11:33 AM
stlduckhunter's Avatar
08 MB GL 320CDI, 07 MB S550, 02 Porsche Cabriolet, 98 MB 450SL, 64 Citreon 2CV
How are you supposed to jump the car if the battery is dead?
Old Sep 13, 2007 | 11:41 AM
jpeardm's Avatar
There are positive and negative connection posts under the hood on the passenger side fenderwall.
Old Sep 13, 2007 | 11:53 AM
SFML320's Avatar
2015 GL550, 2019 GLC350e
Maybe there was already too much weight under the hood. The rear was already full, so under the passenger seat it was. It's probably the least clustered area in the car.
Old Sep 13, 2007 | 01:07 PM
StevethePilot's Avatar
2004 RX330, 2008 Scion xB, 2001 Honda Insight Hybrid, 2010 Toyot Prius v ATP
Hotel Foxtrot Sierra! How very "don't you dare try to service it yourself" of them!
BTW, what's a V1?
STP
Old Sep 13, 2007 | 01:26 PM
FCO's Avatar
FCO
Valentine Rader Detector ( http://www.valentine1.com/ )
Old Sep 13, 2007 | 01:32 PM
BeanCounter's Avatar
GL450 (Alabaster White/Black Interior)
Thanks for the post. I was wandering where it was. Now I know. I really hate when car manufacturers put batteries somewhere else than under the hood. Gives me that warm fuzzy feeling knowing that all that acid and what not is riding shotgun with me.............
Old Sep 13, 2007 | 02:34 PM
HoustonRider's Avatar
06 CLS500
i know the sedans, the battery used to be under the rear seat... in BMW as well..
I don't know about the new ones... its weight distribution for sure... those things weigh 40-50 pounds..
Old Sep 13, 2007 | 08:45 PM
lkchris's Avatar
'10 CL550, '12 GL550
Been years since Mercedes has put a battery under the hood.
Old Sep 14, 2007 | 12:13 AM
WordSmith's Avatar
SL550, ML350, 66 Corvette
My 2005 SL500 has one under the hood and one in the trunk to run the retractable hardtop. Both are easily accessable. This under-the-seat position is a real shocker.
Old Sep 14, 2007 | 12:34 AM
Newbie_2_MB's Avatar
2014 GL 450
Man, am I glad I read this. Being the blonde that I am, I would have probably spent an hour looking under the hood thinking, "Where the heck is the battery?" Even though I didn't see it, I'd still keep looking. I've never owned a car that doesn't have the battery under the hood.
Actually, I'd call Tele-Aid or Auto Club and have them come jump the battery...I'm not risking a nail trying to hook up jumper cables
Old Sep 14, 2007 | 12:59 AM
oknish's Avatar
'07 GL 450, '02 S 80 T6
I went through something similar recently when my wife's Volvo needed a jump start. When I couldn't find the battery under the hood, I pulled out the manual and looked up battery location. In that car, it was in the trunk next to the spare tire with a nice flat metal cover on top. I cursed and then went looking for tools to take the cover off to jump start. Decided to look in manual to see what it said about jump starts and sure enough there are two connection points under the hood clearly labeled + & - for jump starts. Was able to jump start without any issue.
And, now glad to know that same will work for GL also.
Old Sep 14, 2007 | 11:45 AM
MKW's Avatar
MKW
08 GL450
Why would one have to cut the carpet to access the battery ? Shouldn't there have been a " pre-cut " formed into it ? It seems MBZ is asking for trouble having dealer service tech ,owner or local AAA mobile battery replacement guy " go at it " blindly with a blade . I suspect factory service guide has the tech remove the sill plate and then lift that section of carpet . Seems to me that cutting the carpet could introduce tire/susp/running gear noise through the floor pan .
Old Sep 14, 2007 | 12:12 PM
SFML320's Avatar
MBUSA is crossing their fingers that the battery will last the life of the car. (being less than 10 yrs that is)
Even though I'm being sarcastic, a battery will last just as long as it's not being drained all the time.
Old Sep 14, 2007 | 01:08 PM
Pfaelzer's Avatar
GL450
Better weight distribution/lower CG and keep it in a dryer environment than under the hood.
Old Sep 14, 2007 | 06:07 PM
WordSmith's Avatar
I agree. There has to be a better (MB approved) way to access the battery than cutting the carpet. I don't have my GL550 yet, but it will be the first items I look for in the manual when (and if) I take delivery.
Old Sep 14, 2007 | 07:04 PM
lkchris's Avatar
There is indeed a precut.
Old Sep 14, 2007 | 07:09 PM
SUNILP's Avatar
2015 E250D
FCO
You must have shorted pretty bad. Those fuses under the carpet usually never blow unless a heavy draw was placed. Also, cutting the carpet is not required. Just remove the seat.
