Illumination distance for low beam
Old Sep 25, 2007 | 07:24 PM
gas-man's Avatar
'08 GL320 CDI, 2001 996 C4S
My '08 GL 320 has the xenon headlights but it seems that the illumination distance of the low beam is not enough. I would say about 50 to 60 feet. I know that it is self leveling but I always have to click it to high beam. Does anybody feel the same about their headlights? I will have to drop it off one day to the dealer for some service and will have it check.
Old Sep 25, 2007 | 07:34 PM
scottybdiving's Avatar
2008 GL 320, 2007 Silverado LTZ C3500 Duramax Turbo Diesel
I have noticed the same thing. However it is the same with my C3500 Silverado. It seems like the light stops abruptly, creating a line, rather than feathering out. You can see it more clearly when you are on a hilly curvy road.
Old Sep 25, 2007 | 10:18 PM
oknish's Avatar
'07 GL 450, '02 S 80 T6
It is true that Xenon end in a "line" rather than a curve. However, I have not noticed the distance to be short. Seems perfect to me.
Old Sep 25, 2007 | 10:21 PM
boxboss's Avatar
My Bimmers and GL (all with Xenon's) exhibit the same behavior - create a line above the lights and it's especially noticable on hills. This is normal for Xenon's and something you'll get used to.
Old Sep 26, 2007 | 06:46 AM
AsianML's Avatar
2007 E63
Not just xenons, but projector headlights in general. I'm confused about scottybdivings Silverado though. I thought they used the reflector headlights but it has a sharp cutoff too.
Old Sep 26, 2007 | 07:54 AM
xiaohan82's Avatar
08 SL600 AMG(FULLY loaded), 98 SLK230, 06 Suzuki GSXR-1000
I got the same problem with my CLS, I just raised the projector to the highest position possible and that helped with the distant problem a little bit.
Old Oct 11, 2007 | 06:32 PM
gas-man's Avatar
How did you raise the projector? is there a control to do this?
Old Oct 11, 2007 | 08:10 PM
They refer to the upgraded headlights as "Jewel Headlamps" on the LTZ package. They give a very dilineated line.
Old Oct 11, 2007 | 08:17 PM
WordSmith's Avatar
SL550, ML350, 66 Corvette
Is raising the projector something that can be done at home or is it a dealer only service?
Old Oct 11, 2007 | 08:25 PM
AsianML's Avatar
2007 E63
It might be different in the GL, but in my ML there are instructions about two "screws"; one for horizontal adjustment, one for vertical adjustment. This works even for the bi-xenon lights.
Check your GLs manual, it might be in there.
Old Oct 11, 2007 | 08:28 PM
Dodson's Avatar
SL500, ML350, 2 GL550's (on order)
I know on my GMC truck there is a little screw hole on the light casing to aim the beam up or down. Is it something like this for the GL?
