Tail gate closure problems
Old Nov 13, 2007 | 03:52 PM
infamily's Avatar
2014 GL 350 blue tec
Anyone else having sticky tailgate issues? Last 3 or 4 times, our tailgate did not shut all the way and we realize when we see the alarm as we start driving. I use the tailgate button on the door to close again and then it latches. Last night I went in command menu and toggled tailgate limiter option. It seems to be working now but will watch for few days to see if it is fixed.
Old Nov 13, 2007 | 04:45 PM
BeanCounter's Avatar
GL450 (Alabaster White/Black Interior)
I am having the same problem with mine. It does it intermittently and is really annoying to say the least. I am pretty sure some others on this forum have experienced it as well. I am going to get mine fixed next week and will let you know how it goes.
Old Nov 13, 2007 | 05:14 PM
LASCAUX's Avatar
My cargo mat once prevented locking of the gate.
Old Nov 13, 2007 | 05:26 PM
oinick's Avatar
2007 GL 320 CDI, 2008 M5
For the second time now, the mechanism that operates the power liftgate on my GL has failed. The first time it was a pump of some kind and it required two days to fix. I don't know what the problem is for sure this time, but it seems like the same thing.
BTW, it's really hard to open and close manually.
Old Nov 13, 2007 | 06:46 PM
oknish's Avatar
'07 GL 450, '02 S 80 T6
Make sure there are no obstructions around the latch. You probably already did but, in my case, only times I have seen issues is when there was a blockage around the latch.
Old Nov 13, 2007 | 07:06 PM
Nish, that was my thought as well since it was not happening all the time. I ended up taking my cargo liner out to make sure it was not the problem and it is still doing it. I will post the fix. I sure hope mine won't be gone for two days.
Old Nov 14, 2007 | 10:20 AM
oknish's Avatar
Also, make sure to have the dealer check the "close assist". If you notice, when you shut the liftgate, it first comes down and then at the end there is a bit of extra pressure applied to "close" it all the way. If your close assist is not working then the door is not shut all the way and could cause the alarm to come on.
Old Nov 14, 2007 | 11:18 AM
Nish, the close assist you are referring to is my problem. My tailgate goes up and down fine it just does close right all the time. Sometimes that "final stage/extra pressure event" happens at the end sometimes it does not.
Old Nov 14, 2007 | 02:02 PM
infamily's Avatar
Same issues for us.
Old Nov 14, 2007 | 02:29 PM
GLDriver's Avatar
F150,GL450, G63, Aprilia Tuono, Honda Cbx
Hmm
Mine only does that if I start to move the car while it was closing. The Truck should not move while you are operationg the tailgate.
Old Nov 15, 2007 | 11:14 AM
Svalko's Avatar
GL 320 CDI, BMW 325i
I have the same problem, last few days.
Old Nov 16, 2007 | 04:34 PM
mbslk350's Avatar
2021 GLS450, 2015 E250BT 4Matic, 2007 GL320CDI, 2005 SLK350, 2001 SLK320
Ditto here. Someone in another thread observed that the tailgate needs some back pressure to activate the close assist. So, when it doesn't close all the way, I give the tailgate a little tug outward. The close assist will activate and close the tailgate the rest of the way.
If anybody has a dealer-fix, please post. I plan to call it to the dealer's attention at the 10k service (still 4400 miles away).
Old Dec 7, 2007 | 05:37 PM
infamily's Avatar
We had exactly same problem. I dropped the car at dealer this morning, he called and it is supposedly fixed. He adjusted the latch point to make sure there was back pressure for it to close. I will post again in a day or so to let you know if that actually fixed the problem.
Old Dec 8, 2007 | 11:55 AM
Newbie_2_MB's Avatar
2014 GL 450
We had problems with ours last night, not opening when the inside release was pressed. The vehicle was in about 2" of snow and it was in the low 30's. There was quite a bit of snow along the roof line where the rear hatch opens, so I'm not sure if that had anything to do with it or not. I'll try it again this morning (no snow, temps in the 40's).
Old Dec 8, 2007 | 12:41 PM
Still have not gotten mine fixed yet but will let you know when I do. My brakes are starting to squeal like some others have mentioned so I am going to get that addressed as well.........
Old Dec 8, 2007 | 01:07 PM
mrush73's Avatar
2013 GL450
WE have had trouble for he last couple months intermittently with the tailgate closing all the way. However, my wife discovered that the when she starts accelerating the tailgate mechanism will latch and the alarm goes out. We have this happen every couple of weeks and have not had to actually reopen and close it to get it to latch. Now if I can just get the check engine light to keep coming on and off!
Old Dec 10, 2007 | 11:08 AM
infamily's Avatar
Update on tail gate closing
We had similar issues. Dealer adjusted the latch mechanism and that fixed the problem.
Old Feb 22, 2008 | 06:14 PM
woodman438's Avatar
GL320CDI
mine 320cdi has had the same problem and has been in the dealer for more days than i can remember!
anyhow, full credit to the dealer - they did find the problem. there is a strut in the roof lining that actually monitors where the tailgate is - it is basicially a strut with a sensor on it. it goes through the rubber boot bung between the hinge on the top left hand side - it looks like a cable rubber boot - you can see it when the tailgate is open on the upper right hand side.
anyway - the sensor breaks on this strut and the car doesnt know where the tailgate is - hence why when its shut it doesnt operate the closure mech
had this replace (6hr job!) and its all good. interestingly this part wasnt even listed on their parts database hence why it took so long to find
a good test to prove if its the sensor strut is to open the tailgate and the stop it with the remote immeditaley so its only open about 30cms. press the remote again and it should close. if its working correctly it wont close straight away, there will be 2 sec delay - then it will close
if you tailgate doesnt close, or you can hear the motor still going when the door is closed the its the sensor strut that has failed
hope this helps
w
Old Feb 22, 2008 | 09:14 PM
labjr1's Avatar
2006 S430, 2007 GL450, 2007 S550
Mine had the same problem. A trip to the dealer to adjust the latch mechanism fixed the issue.
Old Feb 23, 2008 | 01:54 AM
ksdprasad's Avatar
2007 GL450, 2006 Porsche 911, 2004 VROD
this is a known TSB. dealer fixed it under warranty, they replaced the locking motor.
Old Feb 23, 2008 | 11:23 AM
Jack450's Avatar
GL450
Had mine fixed Wednesday. Advisor said they adjusted it. Works fine now!
Also, said they replaced the dipstick because of a recall. Anyone else?
Old Feb 23, 2008 | 07:09 PM
2014 GL 450
I haven't had the tailgate issue, but did have the dipstick replaced when I took the vehicle in for Service A.
Old Mar 21, 2008 | 04:54 PM
mbslk350's Avatar
Mine's at the dealer today. They replaced the "tailgate motor". Maybe this is the same thing as the "locking motor"? I'll post the part name/number and more details tomorrow after I pick up the car.
Old Mar 22, 2008 | 03:55 PM
mbslk350's Avatar
Well the service advisor might have told me the wrong thing. The receipt says "performed short test, replaced tailgate door latch assembly, verified correct operation". The replacement part is 164-740-04-35 LOCK.
I'm not sure if the door latch assembly is the same as the locking motor or the tailgate motor. Doesn't sound like it.
Bottom line is that it's working again. That's the main thing.
Old Mar 22, 2008 | 10:30 PM
Greul's Avatar
'08 GL 320 CDI (scheduled delivery 3/20/08)
I've had my GL 320 CDI a week now without incident, that was until this afternoon. This morning I read about the tail gate problem here ont he MBWorld site and chuckled with glee "glad it's not happening to mine"....and then the lightning struck. This afternoon after loading groceries closed the tail gate and began to drive off only to encounter an error message "tail gate not closed." Remembered reading about the "back pressure" suggestion/trick earlier in the day and tried it which took care of the problem, at least for now. Seems that the shock or actuator motor doesn't remember how far it has gone and/or needs to go leaving the tail gate slightly open thus returning an error message. Closing the tail gate by hand and giving it a bit of assist on the final closing maneuver also helps. Will have the dealer check things out to make sure. Hats off to this forum...much obliged with all your input, knowledge, and assistance.
And Jack, your GL550 is stunning. What kind of wax do you use?
