GL450 with 22" OZ (pics)
Old Dec 19, 2007 | 09:01 PM
LEOSOPHIE's Avatar
GL550
Originally Posted by patsy1099
A true testament to this fourm. You guys worked it out, to our benefit, without so much as a single bit of sarcasm or slight. Well done!
This was a piece of cake, not like dealing with a spouse.
Old Dec 19, 2007 | 11:17 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Old Dec 20, 2007 | 12:42 AM
gl996tt's Avatar
2007 Mercedes E550
Originally Posted by BlownV8
Using your own calculations and not the calculations based on the tire aspect ratio and rim size, you are still incorrect. His speedometer would be reading faster and not slower as you stated. It would be reading 60.44 since the newer tires rotate 5 more revolutions per mile, according to your figures, and thus would cause the speedometer to read faster than he was actually traveling and not slower.
With all that said, .73% is well within the manufacturers guidelines so you really have nothing to worry about. It was a moot point that was based on the calculations of the aspect ratio and rims and not the manufacturers specs. It has persuaded me, for the time, not to put 22" rims on my GL. I would be worried that the rims would be damaged too often with such a heavy vehicle and a low aspect ratio. AMG got it right with the 21's.
You car does look sweet. Keep us informed of any bent or broken rims.
I also worried about the quality of the wheel too! GL is too heavy for aftermarket wheels. OZ really make good quality wheel that's why I give it a try. I'll update if my wheel got bent or something...
Old Dec 20, 2007 | 01:36 AM
tm4exc's Avatar
E320 & GL450
I provided you with a calculator to determine tire sizes and the effects on speedometers. Use it.
Stock Tire - 265/60R18
Tire 2 - 285/35R22
Section Width: 10.43 in 265 mm
Section Width: 11.22 in 285 mm
Rim Diameter: 18 in 457.2 mm
Rim Diameter: 22 in 558.8 mm
Rim Width Range: 7.5 - 9.5 in
Rim Width Range: 9.5 - 11 in
Overall Diameter: 30.51 in 774.95 mm
Overall Diameter: 29.85 in 758.19 mm
Sidewall Height: 6.25 in 158.75 mm
Sidewall Height: 3.92 in 99.568 mm
Radius: 15.25 in 387.35 mm
Radius: 14.92 in 378.96 mm
Circumference: 95.84 in 2434.3 mm
Circumference: 93.77 in 2381.7 mm
Revs per Mile: 681.7
Revs per Mile: 696.8
Actual Speed: 60 mph 100 km/h
Speedometer with 285/35/18's: 61.3 mph 102. km/h
Speedometer Difference: - Speedometer Difference: 2.215% too fast
Diameter Difference: - Diameter Difference: 2.17%
You are making the assumption that the tire is perfectly fitted to the car at speed. I have a GL450 fitted with the 18' stock wheels and conti tires. My car at 73MPH cruise control on in the flat hits a radar speed indicator (popular item here in the valley as the CHP thinks it controls speed) and my feed back from the sign is blinking between 71 and 72. I support the math for the 40's section size as being correct in this case for the 22's sizing.
Old Dec 20, 2007 | 06:02 PM
BlownV8's Avatar
They look sweet. If they bend, get another rim. I'm just interested to see if they do get bent. If not, I'll probably get 22's or wait until the AMG 21's are readily available at reasonable prices for a cast wheel and not the crazy high prices people are asking.
Old Dec 22, 2007 | 10:14 AM
jeremysm's Avatar
GL450
22" Zinik Rims
I bought my '07 GL 450 and the dealer had installed the Zinik Z1 Shogun Wheels 295x40x22..they look sweet but are you guys saying there's a problem? See pic. Here's a link to the rims..
http://www.1010tires.com/wheel.asp?w...odel=Z1+Shogun
Thoughts? Thanks,
Jeremy
Attached Thumbnails GL450 with 22" OZ (pics)-3325639363_233931015_im1_main_565x421_a_562x421.jpg   GL450 with 22" OZ (pics)-3348444714_233931015_im1_05_565x421_a_562x421.jpg   GL450 with 22" OZ (pics)-dscn3001.jpg   GL450 with 22" OZ (pics)-dscn3003.jpg
Old Dec 22, 2007 | 12:39 PM
  #32
LEOSOPHIE's Avatar
GL550
Thoughts? Thanks,
Jeremy
BlownV8, should we try another one? Speedometer will be reading approx 3% under the actual speed you are traveling. The good thing, if you don't get a ticket, is your waranty will last 3% longer. 660 revs per mile with 22 inch tires versus 680 -685 revs per mile with standard oem tires.
Old Dec 22, 2007 | 06:25 PM
  #33
BlownV8's Avatar
According to the Tire rack, his OEM tires were 275/55/19 Continental 4x4 Contact that do 721 revs per mile. The General UHP do 660 revs per mile. That's a wee bit more than 3%. Ouch!
Leo taught me not to rely on the manufacturers sizes, aspect ratio and rim size, to determine the actual size of the tire.
Old Dec 22, 2007 | 07:10 PM
  #34
LEOSOPHIE's Avatar
GL550
I compared against oem 18's. How did you know he had 19's, just curious. Anyway I agree with the Ouch!
Old Dec 22, 2007 | 11:57 PM
  #35
BlownV8's Avatar
He has the front and rear stainless skid plates. Those come with the 19" wheel package.
Old Dec 23, 2007 | 02:41 AM
  #36
jeremysm's Avatar
GL450
Ouch
My wife is typically at or under the speed limit...lol Interesting to know about the 3-4% for when we drive to CA and I set the cruise to 84mph (when we are really going 87). Thanks for the heads up---I would've thought the speedometer would be set with tire inputs in this day and age....but what do I know.
Old Jan 4, 2008 | 02:24 AM
  #37
vinceching's Avatar
2007 ML 500
It's 450.
I paid $2900 with tires from Tirerack.
It's 22X10 with 50mm offset.
quick question about your offset... can you confirm the offset is et 50.
tirerack has the following... showing an et of 54. i just want to make sure i'm getting the right offset as i remember some other people posting they have a et of 52.
22x10
$608 (each)
Offset: 54mm Bolt Pattern: 5-112
Rec. Tire Size:285/35-22
Weight: 46.2lbs.
Est. Availability: In Stock
Old Jan 16, 2008 | 03:04 PM
  #38
T Class's Avatar
2015 CLS400 | 2009 S550
Looks amazing...I need these bad...
Old Nov 13, 2010 | 05:23 PM
  #39
jey5ive's Avatar
'77 450sl
Where else do they sell those OZ canyon st. 22s? i see them on tire rack. but only in size 20" and the rims alone are $500 each. looks like you got a really good deal. do you know where i can find the same wheel? thanks!
Old Feb 5, 2012 | 03:49 PM
  #40
MrPrometheus's Avatar
2009 GL450
Sorry to bring back an old thread. I just picked up a set of these wheels and need to order some shorter lugbolts. Which ones did you order and do you know if they were coned or rounded?
You have already rated this thread Rating: Thread Rating: 5 votes, 5.00 average.
