Smoke on cold starts
Very weird, I have a 07 GL 450 with 4k on the clock. For some reason she smokes on occasion. It only happens on cold starts and lasts for less than 10 sec. It's bin happening since I purchased the car new. Just wondering if this is normal. Had it checked out twice at the dealer and they gave it a clean bill of health. It pisses me off to see a 70k car smoke like my 20 year old Porsche race car. Is there some kind of oil injector to protect the cylinders on start up? Or should I choke the service manager at MB.
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
It's quite a bit. It could go for days without seeing any smoke at startup. Than all of a sudden smoke. I smelled the smoke an it seems to be a fuel smell combined with burnt oil. It is sickening because it doesn't do it all the time. My original feeling is that it's a leaky injector. It's not happening frequently enough to diagnos properly.
Received 1,067 Likes
E55, GLS450, GL63, GLE350
Does it smoke or are you seeing water vapor that has condensated inside of the exhaust. It has a tendency to create a dirty steam and is burned off from the heat of the exhaust right after start.
![Lightbulb](https://mbworld.org/forums/images/icons/icon3.gif)
I'am with BlownV8. Did you have your car washed recently because if you look at the rear exhaust you'll notice that it slants down at approx. 45 degrees and moisture is easily trapped down there, most typically after a car wash for instance.
I've also noticed a very brief high pitch grinding sound on a cold start right before engine turns over (defining cold as in 20-30 degree temperatures and starting engine after 10+ hours after having shut it off). Sounds odd. Normal?
I get that same noise. It worried me in the beginning but like the others said, seems to be fine. The smoke is troubling, especially for a non-diesel. Is the smoke white? Are you certain it has a strong odor. I would try to pinpoint when it happens to see if the car was wet, etc.
'07 GL 450, '02 S 80 T6
Me too. The smoke seems to be related to the high pitch sound at startup. It doesn't always happen even with the sound. Next time have someone stand behind the car to see if there is any smoke. Sounds like the rings on the pistons are seizing against the block and then breaking free or getting oil. Maybe they built these motors with very low tolerances.
2013 GL450 (traded for 2015 Escalade), 2012 Corvette, 2014 Ford Fusion, Previous: 2007 GL450, 2011
I get the same sound on very cold start...........I also got it on my 2004 Touareg and then also on my 2005 Grand Cherokee under the same cold condtions, so.........I'm thinking its "normal"
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
2006 CLS 500(sold), 2005 C230K, 2005 E 320,
Very weird, I have a 07 GL 450 with 4k on the clock. For some reason she smokes on occasion. It only happens on cold starts and lasts for less than 10 sec. It's bin happening since I purchased the car new. Just wondering if this is normal. Had it checked out twice at the dealer and they gave it a clean bill of health. It pisses me off to see a 70k car smoke like my 20 year old Porsche race car. Is there some kind of oil injector to protect the cylinders on start up? Or should I choke the service manager at MB.![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
The car was perfect though. But the quantity of smoke was just too much to go unnoticed. It would fill up the garage with blueish grey smoke.
Anyway its interesting to notice its happening on a GL
2008 S-550 AMG, 2008 GL450, 2005 Ford F-350, 1998 Bentley Turbo R, 1962 Bentley s-3 Saloon,
I was having the same issue of smoke on my 08 450 when it was a month old they said it was the converter and it has since stopped doing it.
On the way to my office this morning, after 2-3 miles of driving, I noticed a bluish-grey smoke for about a mile, and then it stopped. I did wash the garage kept GL late Sunday PM, & immediately put it to bed. First time the GL belched an exhaust cloud in 1,200 miles.
Water in the exhaust pipe reacting to the heat, bad injector, LSD diesel (labeled as LSD), something else?
If there is no oil consuption and makes a lot of smoke once in a while it's the partices filter regenerating it self.......ans smells bad also. Not to worry. White smoke....could weather, water in the exaust, condensation. Not to worry also. Blue smoke... pay attention to the engine oil deep stick. Check it clousely.
With the winter temperatures setting in, the cold start high pitched grinding sound is back. Brief noise on ignition when engine turns over. Then everything runs fine. No smoke. Did anyone ever figure out whether noise if "normal"?
If it's diesel smoke, you can smell it.
As you know, there's normally no diesel smell from exhaust.
Startup is NOT an exemption for the diesel particulate filter, and if you're smelling diesel exhaust you have a warranty issue.
