GL550 with Brabus Exhaust and new Carlsson Lowering Module (pix)
Old Jan 29, 2008 | 08:08 PM
  #51
CL65's Avatar
GL550
Originally Posted by CL65
It appears the new module is draining my battery again. Today we took it off and will wait and see if the problem continues or if it is indeed the module that is the problem.
I got a new battery and all is fine now since the module is off. I am going in tomorrow to lower the GL back down via the lowering links method and I am going to return the module to Carlsson. After that is finished I will take a video of start up with reving. Hope all is good with everyone
Old Feb 3, 2008 | 08:04 PM
  #52
dwp2002's Avatar
2008 GL450
Your Modifications
Your car looks great!! I had a couple questions about your mods. Is the lowering module a plug and play or are there other modifications that must be done and with the exhaust is it a direct fit or does the rear bumper need to be cut? thanks dwp2002
Old Feb 4, 2008 | 10:23 AM
  #53
CL65's Avatar
GL550
the module is plug and play although, if you look at my last post you will see that it was draining my battery so I have removed the module and lowered the car now via the lowering links method. the exhaust is a direct fit no cutting was required.
Old Feb 6, 2008 | 08:34 PM
  #54
jjtoma's Avatar
07' CLK63 designo Graphite/Black; 07' E350 Sport White/Cashmere
I was wondering how much of a drop did you get with the lowering links.
Is a 2" drop possible without problems.
Old Feb 21, 2008 | 03:44 PM
  #55
GLDriver's Avatar
F150,GL450, G63, Aprilia Tuono, Honda Cbx
Hey
What happened to the larger audio file and any further updates ?
Old Feb 21, 2008 | 07:07 PM
  #56
CL65's Avatar
GL550
I dont know of the exact measurements of the drop, but with the links I am a bit lower than with the module in the pictures I posted. I have yet to have any problems. Sorry for the delay in responding to your question.
  #57
CL65's Avatar
GL550
It totally slipped my mind, my apologies. I will get it done by the end of the weekend.
Old Feb 21, 2008 | 07:16 PM
  #58
oknish's Avatar
'07 GL 450, '02 S 80 T6
That is a very well known side effect of DrivingAGLItis. Other symptoms include forgetting near and dear family members, overwhelming desires to live, eat, and, sleep in the car, etc.
Old Feb 23, 2008 | 02:06 PM
  #59
CL65's Avatar
GL550
http://www.youtube.com/watch?v=PgiCyMbHHWo
here is the new video of start up with some reving.
Old Feb 24, 2008 | 10:15 PM
  #60
Stumblefoot's Avatar
'06 A6 & '08 GL550
Really like the growl while it idles.
Here's another link that provides engine sound out of a non-modified GL550; http://www.youtube.com/watch?v=GVztEt4ghik&NR=1
Old Feb 25, 2008 | 02:08 AM
  #61
oknish's Avatar
Come on CL.....should have red lined it
Sounds great, like Stumble says. I can hear a slight difference between this and my 450.
Old Feb 25, 2008 | 10:41 AM
  #62
CL65's Avatar
GL550
I did make one with it at almost redline but it just didnt sound good. I guess its hard for the camera to pick up how it sounds when you are right next to it or driving for some reason.
Old Feb 25, 2008 | 04:32 PM
  #63
oknish's Avatar
Don't put the camera behind exhaust when filming red lining. Leave it in the car and leave doors open a notch. You should "hear" better results
Old Mar 2, 2008 | 07:17 PM
  #64
kainep's Avatar
AUDI Allroad 3.0tdi
CL65,
Does the module just reset the ride height datum lower or is a completely new configuration?
Kaine
Old Jun 12, 2009 | 03:38 PM
  #65
09 GL550's Avatar
GL 550
are there any tuners/ shops in the Bay area?
Old Jun 27, 2009 | 12:20 PM
  #66
MBW211's Avatar
E500 W211, GL550 X164
hi CL65
do you have any update on the link you install to lower the GL!
I know for the front is has a very similar setup as my wife's e500
All you need it to add couple metal ring then it should be lower!
I'll also try that this week to see the outcome
Old Jun 7, 2010 | 04:38 PM
  #67
09 GL550's Avatar
GL 550
Old Jun 9, 2010 | 08:12 PM
  #68
frabouden's Avatar
GL 320TDI
GL lowering
could someone explain what lowering via the links means? thank you
