Multiple electronic button failure
Old Feb 25, 2008 | 09:16 PM
MDGL320's Avatar
2007 320 CDI GL: soft key position for "back" function, a popular button to use, has stopped working, with no response. Rear door driver's side keyless entry button has failed. Anyone else experience same?
Old Feb 26, 2008 | 12:51 AM
StevethePilot's Avatar
2004 RX330, 2008 Scion xB, 2001 Honda Insight Hybrid, 2010 Toyot Prius v ATP
Nearly a year and some 25K miles later, I've had the following problems; turbo hose failure, twice. Rear liftgate closure adjustment needed, once. Recall on the driveshaft sensor, no failure. Occasionally the interior smells badly, but that's just me. This sounds tremendously anomolous but with the possibility of a water leak as has been experienced by another member. (Who had the problem again?)
In fact my only other problems have been caused externally. The job I was on yesterday I got a small bit of hail damage (amazingly, considering how small the hail itself was).
STP
Old Feb 26, 2008 | 01:53 PM
oinick's Avatar
2007 GL 320 CDI, 2008 M5
STP
That was me. My electrical problems were more serious than yours but I would be skeptical if I were you. Here's the link to the entire thread.
https://mbworld.org/forums/showthrea...ghlight=oinick
BTW, I have not had any electrical problems whatsoever since they diagnosed and corrected the leak...
Good luck.
