Premium Gas?
For the life of me, I can't understand why someone would spend the money for a Mercedes and then cheap out on the gasoline. I only run Chevron premium in my car. Both the previous C240 and the present E350 run much better on Chevron premium. I am averaging 21 mpg with mostly short trips to work (3 miles) and longer trips on weekends.
I also found that using the recommended midgrade in the wife's Chrysler 300 yields better gas mileage by a greater percent than the price differential. The manufacturers make no money from your use of premium.
You may want to search the forums before you post. There have been many threads about this. Other members may not be as kind when you don't search to see if your question has been answered before. I am speaking from newbie experience.
Of course the other freaky part is that the vegetable oil's currently more expensive than the diesel fuel (insane, party of 1?) and I don't think it carries exactly the same energy/weight ratio that petroleum diesel does (i.e. slightly lower mileage) so that doesn't add any incentive to the equation. I just think it'd be kind of cool to drive around on the stuff.
STP
STP
I've been running my New Holland Tractor on B100 during the non-winter months for 5 years now. The tractor runs smoother and quieter with B100. B100 does gel more easily, so I don't use it in the winter. BTW, New Holland only approves of B5. As a word of warning, never introduce anything greater B5 than into an older vehicle. It will disolve all of the crud in your fuel system and clog your injectors.
Injectors are about $800 each and the fuel pump approaches $2K.
Are you feeling lucky?
Now, if I had an old turbo diesel wagon ... I just might!
