Transmission Action - Downshifting
I love my GL and have had no major issues, but I do wish the tranmission were a bit smoother. Perhaps some others can chime in to let us know what their experience has been and whether this is a fixable issue (or something we'll just have to learn to live with).
When these engines are in overrun mode above 1200-1300rpm then they have the fule injectors switched off comlpletly.
If you do feel any SIGNIFICANT jerking during downshifts (predominantly 3-2, 2-1) then I would definately take it to a dealer for further investigation as there are various remedies depending on your exact fault.
One thing I have noticed is that sometimes my idle stays at 950rpm at a stop instead of dropping to 620rpm where it should be. I can't seem to figure out any commonality on this symptom. It seems to be totally random. Any ideas?
What I've found is there are many situations where I might in another car ride my brakes but in my 320 I ride my throttle. One instance is my son's school, where it's a slight downhill around to the back where he's dropped off. I slow to (close to) the 15MPH limit and instead of riding my brakes (if nobody in front of me is slowing or stopping) I gently ride the throttle.
This isn't something you can do on a big hill, but it's a skill you won't generally find use for in a gas car (or at least none that I've driven) with an automatic transmission. It makes me feel a little more in control as I'm going through parking lots, that kind of thing, that I'm right on the throttle if I need it, but going slowly enough that I'll stop immediately with the brakes.
I have 34,000+ miles on my car. Bought it May of last year. I think I'll be driving the wheels completely off of the beautiful beast.
STP
I'm just suggesting that the addition of an air throttle would slow the engine in a more gas-like fashion. Kinda like a Jake brake, but on the intake, rather than exhaust side of the engine....
As for the cold down shift issue, tell your dealer to change the Valve Body NOW.
A re flash is useless. And when winter comes along, trust me your wife will not be able to put on lipstick when it happens. Actually you will find yourself looking in your rear view mirror to see who just rear ended you. Search for rough down shift 7Gtronic.
Occasionally, it feels like someone just bumped into you from the rear. Very disconcerting for a fine automoblile like ours.
I'll keep listing it at every service interval until they get it right.
Let me offer you a little insight into how your transmission works, and based on that, I would say don't worry too much about the hard downshifting for now.
I noticed the same type of shifting that you are describing when our GL was brand new... After a while, it went away, now it shifts butter smooth.
Note that based on my own knowledge of How Automobiles Work, this is a best guess on my part:
Most automatic transmissions these days are what you would call electronically adaptive. They learn how to to operate based on experience... Both with the driver and with the powertrain...
The 7 Speed transmission that the GL uses is the same transmission that many other MZB vehicles use (actually I think almost all of them use) so it was designed to work with many different engine and powertrain combinations.
I suspect that the base programming that is in these transmissions is very generic is intended to be used by as many models as possible, and that based on actual use, the transmission would "learn" how to operate with that vehicle over time.
Since the 450 and 550 use gas engines which do not have the same compression as the diesel, the base program is probably better suited for those engines at first since they build more of them than the diesels. If they had a base program that was better suited for the diesel from the factory, it would probably feel too soft for the gas engines...
The question is, why doesn't MZB have a base program better suited to the diesel... Maybe that is what the dealer is attempting to "re-flash" into the transmission computer. I would be willing to bet that they would rather just have the same base program for the GL320, GL450 and GL550 so that as they are building them, they can just grab one from inventory and toss it into the vehicle no matter which GL version is being built, and that in the end, it would adapt to the vehicle anyway.
I for one am positively hoping this is true.
My transmission could not be smoother and I am sure it was "flashed" during it's latest service if there was a update but not because of my complaints. I am sure some are more conscious than others but drive the car normally, tromp on it a couple of times a day, and don't concentrate on the transmissions performance and soon you will not even have reason to mention these "woes"..:-)
This transmission has been used since early 2006 models and is well known to dealers as well as the people in Alabama and Germany (where they are all made.) I am sure danno has his finger on the pulse of the difficulty getting it perfect for a variety of engines but whatever problems this transmission poses, they are minor and it will adjust as advertised.
I think the 7G is a perfect match for the diesel, more so than the gassers. It maximizes the engines torque and compensates for it's lower RPM's with smaller ratios changes between gears. This is the same principal used in the trannies of the big rigs. Otherwise, they would never be able to addequately power a 5200 lb vehicle with a 3.0L V6.
