Are base halogen headlights good?
Test drive car had only halogens....I'm coming out of 2 past vehicles with HID's and there was NO WAY I was going to get a new GL without HID's after driving that test car. I am a little curious as to why conversion is so difficult though - I converted my wife's Lexus GX with a plug and play kit from xenondepot - took all of 40 minutes...twin ballasts and wiring harnesses etc.
On my end with the HID's I'm a bigger fan of yellow fogs so I'm switching out mine for PIAA Plasma Ion Yellow bulbs...will post some pics when I get around to cleaning - can't post dirty car pics.
I assume that you would need to grind the plastic to make it thin enough for the mount to secure to the housing. By grinding the plastic thin enough for it to catch, I have a feeling it would be a weak spot and the plastic would eventually fail and cause the bulb to fall out of the reflector.
I have not tried to retrofit an HID kit and someone can correct me if I'm wrong. Anyone, anyone, Bueller....Bueller????
By the way, does anyone know where all the mounting points are for the headlights? The two at the top in the engine bay are easily accessible but how do you get to the third one to take out the entire headlight housing? Are there only three bolts that hold it in or are there more?
Happy since.
Happy since.
STP
PS Nobody we know was flying Newark to Buffalo last night, right?
Sorry, it's Monday. I'm not that old, for goodness sake! Just a big Monty Python fan.
And you've really never owned a Toyota or a Lexus? It's a tough comparison, kind of like the beauty, hand made feel, and soul of a Swiss watch versus the soul-less absolute precision of a digital Casio (though of course the price difference isn't nearly as much with the cars and Toyotas nor Lexus..es - Lexi? - are not cheaply made).
STP
STP
here look at some pictures from my detroit autoshow visit...lol
PS Pick up any cheap property in Detroit while you were there? You could probably buy the city of Flint for $20 at this point. Very sad.
, i just got banned from Infiniti FX forum section on freshalloy, saying drving a C-class is much prestige than drving a 2009 FX50...lol
1) Upgrade the halogen bulbs and have dealer re-aim the headlights – result will be much better than stock but not quite as good as HIDs?
2) Use an aftermarket kit such as the MTec kit used by am beagle above – Not sure if the install would be different in a GL; also I read somewhere that MB would need to change the setting in the computer since the light may flicker due to lower wattage(?) am beagle, was that the case? and by any chance can you share a picture of the install?
3) Replace the entire headlight (most costly of the scenarios) and is all that’s needed part #1 in the attached link? I figure MB still needs to change the computer setting?
http://www.trademotion.com/partlocator/index.cfm?action=getJointLocator&siteid=214660&cha pter=&Sectionids=0,2295&groupid=2296&subgroupid=22 97&componentid=85445&make=67&model=GL%20Class&year =2007&graphicID=5791030&callout=1&catalogid=2&disp layCatalogid=0
New HID headlight units from Mercedes is only viable solution.
See http://www.danielsternlighting.com/t...nversions.html
Understand that on forums many folks will defend the cheaper solution in face of engineering data and common sense as if the latter are meaningless. Their degrees in English literature and reading marketing hype help them know all about it.
wow... you do really show ur age...
