07 GL320 CDI - slight smell of diesel fuel?
Old Mar 2, 2009 | 03:05 PM
alx's Avatar
alx
for the last few days i have noticed that after i park the truck in the garage there is a ever so faint smell of diesel fuel coming from under the hood. checked fuel filler door in the back- closed tightly.
my question to the other gl320 cdi owners is - have you noticed such smell. i would have no problem accepting that the smell is normal as long as other trucks do the same.
or i have sprung a fuel leak somewhere...
thank you in advance
alex
few cars
Old Mar 2, 2009 | 04:16 PM
Brocktoon's Avatar
GL 320cdi, Chevrolet Avalanchero, GLE 350 (on order)
Never smelt it. Only places I have detected it are at the oil filler, dipstick, and fuel cap. You might check those areas to make sure all is well.
Old Mar 2, 2009 | 04:34 PM
StevethePilot's Avatar
2004 RX330, 2008 Scion xB, 2001 Honda Insight Hybrid, 2010 Toyot Prius v ATP
Never once.
Old Mar 2, 2009 | 05:10 PM
dieseldoc's Avatar
2022 E350 Diamond White Metallic, 2016 GLC300 Dakota Brown Metallic
never happened
Old Mar 3, 2009 | 09:42 AM
captivabenz's Avatar
14 GL 350, 23Chevy Bolt EV and 22 EUV
I have almost 30,000 miles (07 CDI) and have not had any problem with diesel smell.
Let us know what the mechanic finds...
Old Mar 3, 2009 | 10:52 AM
Comfy_Couch's Avatar
2008 GL 320 CDI
Never had this issue - but I agree check the fuel cap and filler door in case there was a spill there that's causing the odor.
Old Mar 5, 2009 | 12:22 AM
dgiturbo's Avatar
His 2019 RAM Cummins Turbo Diesel Laramie; Her's 2007 ML320 CDI P3; Mine BMW R1200R
Only thing that comes to mind under the hood is the rubber fuel hose that clamp on the fuel filter. Make sure the clamps are tight and no leaks.
Lift up the engine cover and the filter sits top center of the engine. The hose and an electrical connector are on top. Check there for your smell.
Everything else is VERY high pressure and you would probably find that leak really really fast.
Old Mar 5, 2009 | 09:42 AM
thebishman's Avatar
‘24 BMW iX M60
alex
few cars
Alex,
With our '08 CDI I have on occasion smelt the exhaust from the GL. It has a very different smell than a gasoline fueled vehicle. It has been most noticable upon start-up or shut down. It does not seem to be there at all times, but perhaps it is.
Do you think the odor you are noticing is in fact from the exhaust, and not from under the hood?
Bish
Old Mar 5, 2009 | 10:40 AM
scottybdiving's Avatar
2008 GL 320, 2007 Silverado LTZ C3500 Duramax Turbo Diesel
Does anyone know how the particulate filter cleans or regenerates itself? On my Silverado, it periodically does this, usually on long steady highway runs. Often times, when I stop and get out, I notice a smell like a self-cleaning oven or like when you are burning off your gas grill. I don't drive the GL 320 often enough to have smelled this, if they even do the same thing.
Old Mar 5, 2009 | 07:12 PM
Brocktoon's Avatar
The only weird smell I ever encountered was on a very cold day and the exhaust smelt like a cross between ammonia and "simple green" but never a "diesel" smell.
Old Mar 6, 2009 | 09:15 AM
Kaumajet's Avatar
2008 GL320CDI
I've had a slight Diesel smell on very cold mornings from time to time. Nothing found so far, and have never actually seen any fuel anywhere.
