iPod integration kit compatible with any other MP3 players?
Old Jun 17, 2009 | 01:50 PM
ddcha's Avatar
2022 E53 SG
I don't own an iPod, so wondering if I absolutely need to buy one to use the iPod integration kit of if there are any other mp3 players that would be compatible. Thanks in advance.
Old Jun 17, 2009 | 02:22 PM
lkchris's Avatar
'10 CL550, '12 GL550
Should should already have an aux input in your glove box--which is the solution for "any other MP3 player."
Old Jun 17, 2009 | 05:20 PM
Fourdiesel's Avatar
2008 GL 320 CDI, 2004 VW V10 Touareg TDI
In fact, when I ordered mine, I had the choice of the Ipod kit/interface OR the standard MP3 aux jack in the glove box. Couldn't have both!
Old Jun 17, 2009 | 05:21 PM
ddcha's Avatar
2022 E53 SG
So I can use a Sandisk MP3 player with the aux input connector in my glove? I just didn't know whether iPods had different connection ports compared to other MP3 players.
Old Jun 17, 2009 | 08:39 PM
StevethePilot's Avatar
2004 RX330, 2008 Scion xB, 2001 Honda Insight Hybrid, 2010 Toyot Prius v ATP
I think all you need is a cable that will have two "male" ends, plugged in to the "headphone" jack of your Sandisk MP3 player. However, you still have to control it from the actual player. It basically turns the COMAND system into a great big set of headphones. (I know, I know, not that it's much better than that to start with.)
STP
Old Jun 18, 2009 | 08:41 AM
ddcha's Avatar
2022 E53 SG
STP
The iPod integration connector looks like this:
I don't understand where I would plug in the male/male headphone jack.
Old Jun 18, 2009 | 10:40 AM
If you have the iPod integration kit and not the Aux jack, then no you can't use a non-iPod (or, I guess, non-Apple) MP3 player in your truck. If, however, you have both the iPod integration kit and the Aux jack, then you can use the aux jack. I'll get a picture of what the Aux jack looks like in my truck, but basically it's someplace to plug a mini audio jack in to. No cable coming out at all.
STP
Old Jun 18, 2009 | 07:56 PM
Danno4x4's Avatar
2007 GL320 CDI, 2001 TJ Rockcrawler, 2005 Scoobie STI
This thing might work for you...
http://www.cablejive.com/universal-dock-converter
The reason I say might is that it does not work for all integration kits... I don't know who makes the GL class integration kit, so its hard to tell if it will work until you plug it in.
From the company's web page:
Listen to non-iPod audio: This is rare, but on some systems the Universal Dock Converter will let you bypass the need for an attached iPod/iPhone and play audio from another source. Examples include the harman/kardon Go+Play, Enfig auto interfaces, and Logjam auto interfaces.
Old Jun 19, 2009 | 12:29 AM
smsg's Avatar
09 Gl450
Cablejive has been great. I used cablejive as an extension cable and to make my iphone charge. (the current cable only charges the ipod - not the iphone). BTW who's brilliant idea was it to put all of this in the glove box and not the center console???
Old Jun 19, 2009 | 09:20 AM
ddcha's Avatar
2022 E53 SG
very neat stuff. thanks!
