HID Recommendations
This is, of course, purely hypothetical. I don't know what the future holds for my GL. Could be a keep, could be a sell, could be who knows.
Thanks in advance for arguing passionately with each other. Love it.
STP
It's because OEM lamp housings for HID bulbs are designed with different beam pattern as incorporated by the reflector and / or front lens and most of the better systems have leveling systems to compensate for heavy loads in the trunk to prevent blinding oncoming cars .
I have a set of actual HID headlights for the GL. One needs a new lens but you can take it off your stock headlight and transfer it over. I was going to do it on mine but I tried the conversion first and have not looked back. If anyone wants a set of stock GL HID headlights, I'll sell the set, right and left, for $550 delivered anywhere in the continental US.
https://mbworld.org/forums/gl-class-...-pictures.html
I used MTec conversion HID set for more than a year and love it. No complaints from whoever.
The HID bulbs were behind the projectors for low beam= sharp cut.
NOT every OEM-HID car and truck got self-leveling system, only the one with airmatic get it.
Steve:
I bought the used OEM bi-xenons and found out both high and low beam share a same bulb behind the projector. At high beam, a mechanical cover would move to give way to a higher beam.
That would make the install of those OEM ballasts and bulbs into a non-HID light housing more complicated. Still love to find ways to do that.
