2007 GL Rear Entertainment
I bought this used GL450 and it has factory installed RSE and also have IPOD integration kit. I cannot hear the sound int he speaker when I play the DVD. I took it to the dealer and he said that it is designed that way and you can only hear DVD when you put a head set. Is this true?
once you see it, push the button and audio from the dvd will come out of the speakers.
Ipod and rear DVD Sound
Enjoy!
No that didn't help. When I unplug Ipod and play movie and hit AUX under audio menu i get no sound. i still cannot play sound in the speaker, something must not be right. should I be looking at the cabling/connection. Any clue where to start from?
When audio is playing either from iPod or DVD movie, press the "sound" button on the right side of the screen and then select "Logic 7" for surround sound.
If this does not do it, time for a dealer tech, as something is not hooked up right or programmed right in the audio system controller. There are hidden menu's in the drivers console screen by the speedometer that the tech's can use...
Good luck!
It didn't happen in my case. What I beleive that Ipod somehow is taking the DVD input but what surprises me that my dealer told me that RES is not supposed to play in the speaker.
PREMIUM SPONSOR
ML350, Lotus Elise
The fix for this involves ordering a replacement harness for the factory ipod kit called the AACC harness and replacing the existing ipod kit harness. The cost of the harness is about $90US. not sure if you can get them to do this under warranty or not; its technically not a warranty issue so much as a change in the way the vehicle was outfitted...
PREMIUM SPONSOR
ML350, Lotus Elise
check out this thread which outlines the problem in detail
http://www.benzworld.org/forums/gl-c...or-switch.html
PREMIUM SPONSOR
ML350, Lotus Elise
Part number: B67-82-4228
OK, I brought my car back from dealer and he didn't do it. He said "Car has to OP Codes 528 for DVD Function through car speaker. Is this true? am I stuck or what? Can this be done at the midcity Engineering if I bring my car to Chicago (I'm only 3 hr away). rob13572468 can you provide me the pricing etc. you can PM with the price info please.
Thanks.
Thanks.
