May purchase a GL; advice needed please
Thanks in advance
I'm a Ducati Nut
I have/had a 2004 XC90 T6 w/ 75k miles
I dumped the Volvo and bought a 2010 GL450. No regrets. Size wise the GL is a bit longer than the XC and just a pinch wider. It drives much smaller than it looks. Fit and Finish is way above the Volvo. The number of creaks and squeaks from the interior are nill as opposed to the XC90.
Ride wise - it's night and day. Our Volvo was starting to creak and groan from the front suspension. We went thru brake rotors like butter. There were numerous parts that were changed out (steering rack, headlights, motor mounts, head gaskets, ignition switch, various sensors, tie rod ends, etc).
The power from the 450 is also much greater than what we got from the XC. The Transmission is also much improved over the old GM 4 spd in the XC.
This all said - the GL is in the shop now w/ 300 miles for a bad speed sensor which caused an ABS / ESP warning light to come on.. :-)
Good Luck w/ the new Truck..
Alex
I also just replaced my OEM Conti's at 37.5K I probably should have replaced them at 35K, but we were in a drought, our roads are good, and she is not an aggressive driver. I replaced them with the same.
